주요 콘텐츠로 건너뛰기
PlayStation 3 Super Slim Power Supply Unit Replacement
필요한 것
  1. PlayStation 3 Super Slim Power Supply Unit Replacement, Power Supply Unit: 1 단계, 이미지 2개 중 1개 PlayStation 3 Super Slim Power Supply Unit Replacement, Power Supply Unit: 1 단계, 이미지 2개 중 2개
    • Remove the side HDD bay cover by sliding the panel towards the back of the device.
    • The bay cover is found on the right side of the device.
  2. PlayStation 3 Super Slim Power Supply Unit Replacement: 2 단계, 이미지 2개 중 1개 PlayStation 3 Super Slim Power Supply Unit Replacement: 2 단계, 이미지 2개 중 2개
    • Remove all three black 9.8mm long screws with a T-8 security screwdriver.
    • Remove the blue 7.9mm long screw with a Phillips #1 screwdriver.
  3. PlayStation 3 Super Slim Power Supply Unit Replacement: 3 단계, 이미지 2개 중 1개 PlayStation 3 Super Slim Power Supply Unit Replacement: 3 단계, 이미지 2개 중 2개
    • Pull on the tab to remove the HDD.
    • The HDD should be removed and stored carefully to prevent damage to data.
  4. PlayStation 3 Super Slim Power Supply Unit Replacement: 4 단계, 이미지 2개 중 1개 PlayStation 3 Super Slim Power Supply Unit Replacement: 4 단계, 이미지 2개 중 2개
    • On the bottom of the device, pry out the three rubber feet covers with the metal spudger.
    • Remove the four black 36.3mm long screws underneath with a Phillips #1 screwdriver.
    • One screw is located underneath the warranty sticker. This sticker can either be peeled off or punctured through with a screwdriver.
  5. PlayStation 3 Super Slim Power Supply Unit Replacement: 5 단계, 이미지 2개 중 1개 PlayStation 3 Super Slim Power Supply Unit Replacement: 5 단계, 이미지 2개 중 2개
    • On the top of the device, unlatch the hook on the furthest right beneath the front panel, lift the panel slightly and apply pressure.
    • Unlatch the second right-side hook by sliding a plastic opening tool in the marked area.
    • Slide the panel to the left to unlatch the rest of the hooks.
    • This is probably the most difficult part of the procedure. If you cannot unlatch the hook on the front panel, you can attempt to pry all the hooks off. However, do this at your own risk, as these hooks break easily.
  6. PlayStation 3 Super Slim Power Supply Unit Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the back panel by pressing down the tab on the right side of the device, and sliding the panel to the left.
  7. PlayStation 3 Super Slim Power Supply Unit Replacement: 7 단계, 이미지 3개 중 1개 PlayStation 3 Super Slim Power Supply Unit Replacement: 7 단계, 이미지 3개 중 2개 PlayStation 3 Super Slim Power Supply Unit Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the five silver 20.8mm long screws with a Phillips #1 screwdriver.
    • Remove the two black 9.9mm long screws in the disc reader with a T-8 security screwdriver.
    • Remove the top black plastic shell.
  8. PlayStation 3 Super Slim Power Supply Unit Replacement: 8 단계, 이미지 3개 중 1개 PlayStation 3 Super Slim Power Supply Unit Replacement: 8 단계, 이미지 3개 중 2개 PlayStation 3 Super Slim Power Supply Unit Replacement: 8 단계, 이미지 3개 중 3개
    • Move the optical drive to the side to reveal one of the silver 8.8mm long screws.
    • Remove the two silver 8.8mm long screws on either side with a Phillips #1 screwdriver.
  9. PlayStation 3 Super Slim Power Supply Unit Replacement: 9 단계, 이미지 3개 중 1개 PlayStation 3 Super Slim Power Supply Unit Replacement: 9 단계, 이미지 3개 중 2개 PlayStation 3 Super Slim Power Supply Unit Replacement: 9 단계, 이미지 3개 중 3개
    • Remove the cable from the plug and remove the wires from the two plastic hooks.
    • When removing the cable from the plug, pull on the plastic male connecter, not on the wires.
    • Remove the power supply unit.
결론
Install the replacement power supply unit. To reassemble your device, follow these instructions in reverse order.
다른 30명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Joseph O'Connor
회원 가입일: 04/14/16
2,775 평판
안내서 5개를 작성함
Cal Poly, Team 34-13, Maness Spring 2016 Cal Poly, Team 34-13, Maness Spring 2016 회원
CPSU-MANESS-S16S34G13
4 회원들
안내서 24개를 작성함
댓글 8개
Perfect how to guide. Fixed my PS3 easily. Thanks
Andrew Roscoe - 답글
Great guide. However, still no power on PS3. Any suggestions as to what else may be the problem?
Peter Maher - 답글
Peter Maher, I am in the same boat. I have no idea what the problem is. Red light in standby, but as soon as I try to power on, nothing. Same as before I did this power supply replacement. Obviously, something else is the problem. Anyone who has some insight into this please help!
James Neely - 답글
Did you guys get word on the red light with no power on fix mine has the same issue.
Benjamin P Patterson -
i have the same problem as Peter Maher, the red light is in standby neither turning green on pressing nor it sounds beep on long press. dont know whats wrong. anyone has any solution to this?
Thiemwang Kitnya - 답글
댓글 쓰기
조회 통계:
지난 24시간: 13
지난 7일: 112
지난 30일: 517
전체 시간: 33,590
