주요 콘텐츠로 건너뛰기
소개
Add washers underneath the APU leafspring to stop the blinking blue light.
For steps on how to get to this stage, please search for a guide to teardown a PS4 Gen 1 or 2 depending on which one you have. You only need to take the top off of the Gen 1, and for the Gen 2 you will need to remove the top plastic as well as the top metal shielding.
The washers used are 1mm outer diameter, about 5/10mm inner diameter, and 2/10mm thickness. Made out of nylon/plastic.
For the Gen 1 Playstation 4 (the first model with the capacitive touch button) place 1 nylon/plastic washer under the leafspring on each screw and tighten down. Do not overtighten or it will cause the same issue.
For the Gen 2 Playstation 4 (second revision with the physical press button for power and eject) place two stacked washers underneath the leafspring on each screw, so not over tighten.
  1. Place washer underneath leafspring. 2 washers per screw on gen 2 playstation 4, the one pictured above. Place washer underneath leafspring. 2 washers per screw on gen 2 playstation 4, the one pictured above.
    • Place washer underneath leafspring. 2 washers per screw on gen 2 playstation 4, the one pictured above.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kasey Yeagley
회원 가입일: 2017년 03월 24일
110 평판
안내서 1개 작성함
댓글 한 개
This will completely ruin the PS4 motherboard in the long run with the boards getting extremely warped this happened long ago with xbox 360 board the true solution is to replace the apu chip and or ram chips or to replace the entire motherboard with daughte
The invader 2 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 36
30일 전: 218
전체 시간: 4,825
