주요 콘텐츠로 건너뛰기
PlayStation 4 Pro Power Supply Assembly Guide
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. PlayStation 4 Pro Power Supply Assembly Guide, Hard Drive Caddy: 1 단계, 이미지 1/3 PlayStation 4 Pro Power Supply Assembly Guide, Hard Drive Caddy: 1 단계, 이미지 2/3 PlayStation 4 Pro Power Supply Assembly Guide, Hard Drive Caddy: 1 단계, 이미지 3/3
    • Flip the console upside down.
    • Use your finger to pull and snap off the plastic cover over the hard drive.
  2. PlayStation 4 Pro Power Supply Assembly Guide: 2 단계, 이미지 1/2 PlayStation 4 Pro Power Supply Assembly Guide: 2 단계, 이미지 2/2
    • Use a Phillips #1 Screwdriver to remove the single screw securing the hard drive caddy.
    • Pull the hard drive caddy straight out.
  3. PlayStation 4 Pro Power Supply Assembly Guide, Power Supply Assembly: 3 단계, 이미지 1/3 PlayStation 4 Pro Power Supply Assembly Guide, Power Supply Assembly: 3 단계, 이미지 2/3 PlayStation 4 Pro Power Supply Assembly Guide, Power Supply Assembly: 3 단계, 이미지 3/3
    • Flip the console right side up.
    • Grip the two corners located at the front of the device.
    • Pull upwards until a loud click is heard.
    • This may require a lot of force, so do not be afraid to get a little rough with your console.
    • After both corners detach, slide the cover backwards and lift off.
  4. PlayStation 4 Pro Power Supply Assembly Guide: 4 단계, 이미지 1/3 PlayStation 4 Pro Power Supply Assembly Guide: 4 단계, 이미지 2/3 PlayStation 4 Pro Power Supply Assembly Guide: 4 단계, 이미지 3/3
    • Use a T8 Torx Security screwdriver to remove five screws from the rear of the device.
    • Two 31mm screws.
    • Three 10mm screws for the 7000 models; Two gray 10mm screws (upper and lower screws on the illustration) if the PS4 Pro is a 7100-series model.
    • Remove the metal plate by pulling it up.
  5. PlayStation 4 Pro Power Supply Assembly Guide: 5 단계, 이미지 1/3 PlayStation 4 Pro Power Supply Assembly Guide: 5 단계, 이미지 2/3 PlayStation 4 Pro Power Supply Assembly Guide: 5 단계, 이미지 3/3
    • Flip the console over so the bottom is facing up.
    • Use a T8 Torx Security screwdriver to remove the three black 7mm screws in the back panel. (7000-series models only); or one 7mm screw (the middle one) with 7100-series models and the warranty sticker to the left.
    • Remove the bottom cover in the same way as the top cover. Grip the cover on both sides and pull up until it clicks. Then slide the cover off; With 7100-series models, pay attention to the two clips that replace the corresponding screws.
  6. PlayStation 4 Pro Power Supply Assembly Guide: 6 단계, 이미지 1/3 PlayStation 4 Pro Power Supply Assembly Guide: 6 단계, 이미지 2/3 PlayStation 4 Pro Power Supply Assembly Guide: 6 단계, 이미지 3/3
    • Use a T8 Torx security screwdriver to remove the eleven 10mm silver screws from the metal plate.
    • Use a Phillips #1 screwdriver to remove the eleven 4mm black screws from the metal plate.
    • 7200-series models have 13 additional 4mm screws around the top and right of the metal plate. These screws are are indicated with a triangle. This may apply to other models.
    • Use a spudger to disconnect the three antenna cables (two black and one white) by prying them straight up from their sockets.
  7. PlayStation 4 Pro Power Supply Assembly Guide: 7 단계, 이미지 1/2 PlayStation 4 Pro Power Supply Assembly Guide: 7 단계, 이미지 2/2
    • Pull the white fan connector straight out of the yellow mount on the motherboard.
  8. PlayStation 4 Pro Power Supply Assembly Guide: 8 단계, 이미지 1/2 PlayStation 4 Pro Power Supply Assembly Guide: 8 단계, 이미지 2/2
    • Pull out the five small, blue low profile cables connected to the metal plate.
    • Lift the retaining flap on the ZIF connector of the large ribbon cable.
    • Pull the large ribbon cable from its socket.
    • Do not pull on the biggest blue cable without lifting the tab first. Doing so can damage the connection.
  9. PlayStation 4 Pro Power Supply Assembly Guide: 9 단계, 이미지 1/1
    • Pull up and remove the metal plate.
  10. PlayStation 4 Pro Power Supply Assembly Guide: 10 단계, 이미지 1/3 PlayStation 4 Pro Power Supply Assembly Guide: 10 단계, 이미지 2/3 PlayStation 4 Pro Power Supply Assembly Guide: 10 단계, 이미지 3/3
    • Flip the console over to continue working on the top side.
    • Pull up on the power supply unit and set it on the console.
    • Be careful not to pull too far, the assembly is still connected at one point.
    • Grip the connector behind the power supply and pull straight out.
결론
Thomas
회원 가입일: 04/26/17
3,877 평판
안내서 5개 작성하였습니다
Cal Poly, Team S21-G5, Livingston Spring 2017 Cal Poly, Team S21-G5, Livingston Spring 2017 회원
CPSU-LIVINGSTON-S17S21G5
4 회원들
안내서 49개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 13
전체 시간: 447
