소개
This guide will go through the steps necessary to remove the power supply unit from the PlayStation 4 Pro. Some disassembly is required for this removal, but it is one of the first things that can be removed from the PS4 Pro.
필요한 것
Begin by flipping the console upside down.
Use your finger to pull and snap off the plastic cover over the hard drive.
Use a T8 Torx Security screwdriver to remove the five screws.
Two 31mm screws.
Three 10mm screws.
Remove the metal plate.
I couldn’t open the middle 10mm screw with T8 Torx Security screwdriver :(
Rifat Nabi - 답글
How do I get the middle plastic black screw out? It's not doing anything but stripping it.
it’s like rubber or something on that middle screw.
On newer models the black screw in the middle is just plastic and does not have to be removed. Skip it or you’ll just drive yourself crazy and end up producing a small pile of plastic-dust and that’s it.
Flip the console to its back once again.
Use a T8 Torx Security screwdriver to remove the three black 7mm screws in the back panel.
Remove the bottom cover in the same way as the top cover. Grip on both sides, pull up until a click is heard and slide off.
If you have a console that has not been fixed before - these screws will be hidden under warranty stickers - so make sure you understand that completing this step will basically void the warranty.
Flip the console over to continue working on the top side.
Place fingers underneath edge of power supply unit on both sides and pull straight up.
Grip the connector behind the power supply and pull straight out.
what kind of wire is that ive been looking everywhere for a replacement
There are 3 different power supplies for the pro model.......... take it apart and read the numbers off it to make sure you get the correct one. 300ER, 300CR, 300FR
Alan Sears - 답글
This is the only screw I can't get out on top of the power supply so I can replace my pasta what size is it
This is the screw I had trouble with I don't know why and it's the only screw holding the power supply in on top in the middle when you take the foil off
다른 36명이 해당 안내서를 완성하였습니다.
댓글 10개
I bought a PS4 power supply CR 300 and my PS4 has an FR 300 power supply will they interchange
My PlayStation Pro has a power supply FR 300 and the power supply I bought was a CR 300 power supply will they interchange
Hola como saber que tipo de fuente vida mi ps4 pro modelo 7215b
Solucionaste el problema?
for anyone attempting this please note that the motherboard connector for the power supply is very fragile and might break off will trying to disconnect. Try pinching the connector on the motherboard and gently pulling on the cables to try and keep that from happening
Good morning do you have a number to call for I can call about a ps4 Pro
Because I need my PS4 to get fixed I think one of the cords inside of it is broken and it do not want to turn on and stuff like that so ya what is the number I can contact you on
