주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
PlayStation 4 Slim Bottom Cover Replacement
필요한 것
  1. PlayStation 4 Slim Bottom Cover Replacement, Bottom Cover: 1 단계, 이미지 1/3 PlayStation 4 Slim Bottom Cover Replacement, Bottom Cover: 1 단계, 이미지 2/3 PlayStation 4 Slim Bottom Cover Replacement, Bottom Cover: 1 단계, 이미지 3/3
    • Locate the plastic warranty sticker next to the three ports on the side of the console.
    • Remove the warranty sticker by peeling it off with any kind of spudger.
    • Removing the warranty sticker will NOT cause your warranty to be null and void.
  2. PlayStation 4 Slim Bottom Cover Replacement: 2 단계, 이미지 1/2 PlayStation 4 Slim Bottom Cover Replacement: 2 단계, 이미지 2/2
    • Unscrew and remove the 5.0mm screw that was behind the sticker using a T8 security Torx screwdriver with a counter-clockwise motion.
  3. PlayStation 4 Slim Bottom Cover Replacement: 3 단계, 이미지 1/3 PlayStation 4 Slim Bottom Cover Replacement: 3 단계, 이미지 2/3 PlayStation 4 Slim Bottom Cover Replacement: 3 단계, 이미지 3/3
    • Place the Playstation 4 Slim upside down with the side of the screw you just removed facing you.
    • Pry up on the two corners that are facing you with your fingers.
    • This may take a bit of force to open up and you will hear a fairly loud click when the bottom cover detaches.
    • Remove the bottom cover by sliding it towards the back corners and lifting up.
결론
다른 36명이 해당 안내서를 완성하였습니다.
Hernan Rodriguez
회원 가입일: 01/24/18
3,642 평판
안내서 3개 작성하였습니다
Cal Poly, Team S19-G4, Livingston Winter 2018 Cal Poly, Team S19-G4, Livingston Winter 2018 회원
CPSU-LIVINGSTON-W18S19G4
4 회원들
안내서 35개 작성하였습니다
댓글 2개
Wo kann man die Bodenplatte kaufen?
Emre Kaman - 답글
댓글 쓰기
조회 통계:
24 시간 전: 19
7일 전: 185
30일 전: 799
전체 시간: 47,351
