소개
Use this guide to remove and replace the fan system in your PS4 Slim.
필요한 것
Locate the plastic warranty sticker next to the three ports on the side of the console.
Remove the warranty sticker by peeling it off with any kind of spudger.
Place the Playstation 4 Slim right side up, with the PS logo on top and the side with the words "SONY" and "PS4" facing you.
Pry up on the two corners that are facing you with your fingers.
Remove the top cover by sliding it towards the back corners and lifting up.
Unscrew and remove the 31.0mm safety screw using a T8 screwdriver with a counter-clockwise motion.
Flip the device to the backside.
Unscrew and remove 14x (19x for CUH-21xx) 4.0mm black screws using a Phillips #1 screwdriver with a counter-clockwise motion.
Unscrew and remove 8x (7x for CUH-21xx) 6.0mm silver screws using a Phillips #1 screwdriver with a counter-clockwise motion.
Unscrew and remove 4x 3.0mm silver screws using a Phillips #1 screwdriver with a counter-clockwise motion.
Locate the white wire connected to the corner of the top of the motherboard.
Disconnect the wire by firmly grasping the metal connection with your fingers or tweezers and pulling up until it detaches.
Unthread the wire from the tape and move it off to the side using tweezers or your fingers.
Unscrew and remove the six 4.0mm screws using a PH00 screwdriver with a counter-clockwise motion.
다른 64명이 해당 안내서를 완성하였습니다.
댓글 5개
Thank you so much for this guide! It was very helpful!
Deine Schrauben großen machen gar kein Sinn du hast mehr verschiedene Schrauben als es gibt
My PS4 “Slim” is quite different internally than the one shown. But regardless, this guide is an excellent resource for us diy’ers. And don’t forget any parts when reassembling, like I did. Took four tries to get everything back where it belonged. And man, was it dusty in there! Regular cleaniings are a must.
My ps4 slim is different it has some extra parts, now I don’t know how to put it back, hahahahahhahaha
This guide gets you 90% of the way there. Some really important pieces are missing though, primarily:
- How you dont need to unplug the power supply cable from the motherboard, you can just unhook it from the plastic clips on the case.
- It never mentions cleaning the old Thermal Paste off the heatsink + cpu and replacing with a new dab.
Both of these are essential for a proper tear-down. If you dont replace the thermal paste, your PS4 is guaranteed to break down irreparably in the future. I had to know or discover them for myself. Please, please update this guide with that info.
