주요 콘텐츠로 건너뛰기
소개
Use this guide to remove and replace the fan system in your PS4 Slim.
  1. Locate the plastic warranty sticker next to the three ports on the side of the console. Remove the warranty sticker by peeling it off with any kind of spudger. Removing the warranty sticker will NOT cause your warranty to be null and void.
    • Locate the plastic warranty sticker next to the three ports on the side of the console.
    • Remove the warranty sticker by peeling it off with any kind of spudger.
    • Removing the warranty sticker will NOT cause your warranty to be null and void.
  2. Unscrew and remove the 5.0mm screw that was behind the sticker using a T8 security Torx screwdriver with a counter-clockwise motion. Unscrew and remove the 5.0mm screw that was behind the sticker using a T8 security Torx screwdriver with a counter-clockwise motion.
    • Unscrew and remove the 5.0mm screw that was behind the sticker using a T8 security Torx screwdriver with a counter-clockwise motion.
  3. Place the Playstation 4 Slim upside down with the side of the screw you just removed facing you. Pry up on the two corners that are facing you with your fingers. This may take a bit of force to open up and you will hear a fairly loud click when the bottom cover detaches.
    • Place the Playstation 4 Slim upside down with the side of the screw you just removed facing you.
    • Pry up on the two corners that are facing you with your fingers.
    • This may take a bit of force to open up and you will hear a fairly loud click when the bottom cover detaches.
    • Remove the bottom cover by sliding it towards the back corners and lifting up.
  4. Place the Playstation 4 Slim right side up,  with the PS logo on top and the side with the words "SONY" and "PS4" facing you. Pry up on the two corners that are facing you with your fingers. This may take a bit of force to open and you will hear a fairly loud click when the top cover detaches.
    • Place the Playstation 4 Slim right side up, with the PS logo on top and the side with the words "SONY" and "PS4" facing you.
    • This may take a bit of force to open and you will hear a fairly loud click when the top cover detaches.
    • Remove the top cover by sliding it towards the back corners and lifting up.
  5. Unscrew and remove the two screws (left one 31.0mm and right one 24.0mm) using a T8 screwdriver with a counter-clockwise motion. Unscrew and remove the 3.0mm screw using a Phillips #1 screwdriver with a counter-clockwise motion. Unscrew and remove the 3.0mm screw using a Phillips #1 screwdriver with a counter-clockwise motion.
    • Unscrew and remove the two screws (left one 31.0mm and right one 24.0mm) using a T8 screwdriver with a counter-clockwise motion.
    • Unscrew and remove the 3.0mm screw using a Phillips #1 screwdriver with a counter-clockwise motion.
  6. Remove the four 16mm Philips screws holding the power supply in place.
    • Remove the four 16mm Philips screws holding the power supply in place.
  7. Remove the metal sheet from the top of  the power supply by grabbing and lifting up with your hands. Remove the metal sheet from the top of  the power supply by grabbing and lifting up with your hands.
    • Remove the metal sheet from the top of the power supply by grabbing and lifting up with your hands.
  8. Remove the antenna from the top of the power supply by guiding the wire with your fingers through the groves underneath the metal panel. Remove the antenna from the top of the power supply by guiding the wire with your fingers through the groves underneath the metal panel.
    • Remove the antenna from the top of the power supply by guiding the wire with your fingers through the groves underneath the metal panel.
  9. Flip the Playstation 4 Slim onto its back. Unscrew and remove the 4.0mm screw using a Phillips #1 screwdriver with a counter-clockwise motion.
    • Flip the Playstation 4 Slim onto its back.
    • Unscrew and remove the 4.0mm screw using a Phillips #1 screwdriver with a counter-clockwise motion.
  10. Use a plastic opening tool to make space between the power supply and console by wedging and wiggling it in-between the two. Lift the power supply up and onto its back on the metal sheet using your hands. Lift the power supply up and onto its back on the metal sheet using your hands.
    • Use a plastic opening tool to make space between the power supply and console by wedging and wiggling it in-between the two.
    • Lift the power supply up and onto its back on the metal sheet using your hands.
  11. Disconnect the wire connection from the power supply by firmly gripping it with your fingers or tweezers and pulling out. Remove the power supply completely by grabbing and lifting up with your hands. Remove the power supply completely by grabbing and lifting up with your hands.
    • Disconnect the wire connection from the power supply by firmly gripping it with your fingers or tweezers and pulling out.
    • Remove the power supply completely by grabbing and lifting up with your hands.
  12. Unscrew and remove the 31.0mm safety screw using a T8 screwdriver with a counter-clockwise motion. Unscrew and remove the 31.0mm safety screw using a T8 screwdriver with a counter-clockwise motion.
    • Unscrew and remove the 31.0mm safety screw using a T8 screwdriver with a counter-clockwise motion.
  13. Locate the two wires connected to the bottom of the motherboard. Remove the wires by firmly grasping the metal connections with your fingers or tweezers and pulling up until they disconnect.
    • Locate the two wires connected to the bottom of the motherboard.
    • Remove the wires by firmly grasping the metal connections with your fingers or tweezers and pulling up until they disconnect.
  14. Flip the device to the backside. Unscrew and remove 14x 4.0mm black screws using a Phillips #1 screwdriver with a counter-clockwise motion.
    • Flip the device to the backside.
    • Unscrew and remove 14x 4.0mm black screws using a Phillips #1 screwdriver with a counter-clockwise motion.
    • Unscrew and remove 8x 6.0mm silver screws using a Phillips #1 screwdriver with a counter-clockwise motion.
    • Unscrew and remove 4x 3.0mm silver screws using a Phillips #1 screwdriver with a counter-clockwise motion.
  15. Unscrew and remove the two 5.0mm screws on the side of the console using a Phillips #1 screwdriver with a counter-clockwise motion. Unscrew and remove the two 5.0mm screws on the side of the console using a Phillips #1 screwdriver with a counter-clockwise motion.
    • Unscrew and remove the two 5.0mm screws on the side of the console using a Phillips #1 screwdriver with a counter-clockwise motion.
  16. Locate the white wire connected to the corner of the top of the motherboard. Disconnect the wire by firmly grasping the metal connection with your fingers or tweezers and pulling up until it detaches. Unthread the wire from the tape and move it off to the side using tweezers or your fingers.
    • Locate the white wire connected to the corner of the top of the motherboard.
    • Disconnect the wire by firmly grasping the metal connection with your fingers or tweezers and pulling up until it detaches.
    • Unthread the wire from the tape and move it off to the side using tweezers or your fingers.
  17. Remove the connections by pulling out on the blue tabs with your fingers. Flip up the black clip on the largest tab with your finger before removing it. Remove this wire connection by firmly gripping the wire with your fingers and pulling it out.
    • Remove the connections by pulling out on the blue tabs with your fingers.
    • Flip up the black clip on the largest tab with your finger before removing it.
    • Remove this wire connection by firmly gripping the wire with your fingers and pulling it out.
  18. Remove the metal plate by grabbing two sides of the plate and lifting up and away from yourself. You may need to wiggle the plate a bit to get it loose before you lift it out.
    • Remove the metal plate by grabbing two sides of the plate and lifting up and away from yourself.
    • You may need to wiggle the plate a bit to get it loose before you lift it out.
    • Do not lose any of the black pads attached to the motherboard while performing this step.
  19. Unscrew and remove the two 10.0mm screws (one silver and one black) using a Phillips #1 screwdriver with a counter-clockwise motion. Remove the small metal plate by grabbing it with your fingers and lifting up. Remove the small metal plate by grabbing it with your fingers and lifting up.
    • Unscrew and remove the two 10.0mm screws (one silver and one black) using a Phillips #1 screwdriver with a counter-clockwise motion.
    • Remove the small metal plate by grabbing it with your fingers and lifting up.
  20. Remove this wire connection by firmly grasping it with tweezers and pulling out. This might require a bit of force to disconnect, but be sure not to break any of the wires. This might require a bit of force to disconnect, but be sure not to break any of the wires.
    • Remove this wire connection by firmly grasping it with tweezers and pulling out.
    • This might require a bit of force to disconnect, but be sure not to break any of the wires.
  21. Remove the motherboard by grabbing the edge of the board with one or two hands and pulling away and up. You may need to wiggle the board a bit to get it loose before you remove it.
    • Remove the motherboard by grabbing the edge of the board with one or two hands and pulling away and up.
    • You may need to wiggle the board a bit to get it loose before you remove it.
  22. Unscrew and remove the six 4.0mm screws using a PH00 screwdriver with a counter-clockwise motion. Unscrew and remove the six 4.0mm screws using a PH00 screwdriver with a counter-clockwise motion.
    • Unscrew and remove the six 4.0mm screws using a PH00 screwdriver with a counter-clockwise motion.
  23. Remove the metal plate by grabbing the edges and lifting up with your hands. Remove the metal plate by grabbing the edges and lifting up with your hands.
    • Remove the metal plate by grabbing the edges and lifting up with your hands.
  24. Unscrew and remove the two 4.0 mm screws using a PH00 screwdriver with a counter-clockwise motion. Unscrew and remove the two 4.0 mm screws using a PH00 screwdriver with a counter-clockwise motion.
    • Unscrew and remove the two 4.0 mm screws using a PH00 screwdriver with a counter-clockwise motion.
  25. Remove the fan system by grabbing the edge of the top metal plate and lifting up with your hands. Remove the fan system by grabbing the edge of the top metal plate and lifting up with your hands.
    • Remove the fan system by grabbing the edge of the top metal plate and lifting up with your hands.
결론
다른 33명이 해당 안내서를 완성하였습니다.
Harry Koos
회원 가입일: 2018년 01월 24일
3,287 평판
안내서 2개 작성하였습니다
Cal Poly, Team S19-G4, Livingston Winter 2018 Cal Poly, Team S19-G4, Livingston Winter 2018 회원
CPSU-LIVINGSTON-W18S19G4
4 회원들
안내서 31개 작성하였습니다
댓글 4개
Thank you so much for this guide! It was very helpful!
David Rodriguez - 답글
Deine Schrauben großen machen gar kein Sinn du hast mehr verschiedene Schrauben als es gibt
Andre Hollmann - 답글
My PS4 “Slim” is quite different internally than the one shown. But regardless, this guide is an excellent resource for us diy’ers. And don’t forget any parts when reassembling, like I did. Took four tries to get everything back where it belonged. And man, was it dusty in there! Regular cleaniings are a must.
Patrick Ogren - 답글
My ps4 slim is different it has some extra parts, now I don’t know how to put it back, hahahahahhahaha
Lancelotte Fabros - 답글
댓글 쓰기
조회 통계:
24 시간 전: 65
7일 전: 453
30일 전: 1,648
전체 시간: 55,305
