주요 콘텐츠로 건너뛰기
PlayStation 4 Slim Optical Disc Drive Replacement
필요한 것
  1. PlayStation 4 Slim Optical Disc Drive Replacement, Bottom Cover: 1 단계, 이미지 1/3 PlayStation 4 Slim Optical Disc Drive Replacement, Bottom Cover: 1 단계, 이미지 2/3 PlayStation 4 Slim Optical Disc Drive Replacement, Bottom Cover: 1 단계, 이미지 3/3
    • Locate the plastic warranty sticker next to the three ports on the side of the console.
    • Remove the warranty sticker by peeling it off with any kind of spudger.
    • Removing the warranty sticker will NOT cause your warranty to be null and void.
  2. PlayStation 4 Slim Optical Disc Drive Replacement: 2 단계, 이미지 1/2 PlayStation 4 Slim Optical Disc Drive Replacement: 2 단계, 이미지 2/2
    • Unscrew and remove the now exposed 5.0mm screw using a T8 security Torx screwdriver with a counter-clockwise motion.
  3. PlayStation 4 Slim Optical Disc Drive Replacement: 3 단계, 이미지 1/3 PlayStation 4 Slim Optical Disc Drive Replacement: 3 단계, 이미지 2/3 PlayStation 4 Slim Optical Disc Drive Replacement: 3 단계, 이미지 3/3
    • Place the Playstation 4 Slim upside down with the side of the screw you just removed facing you.
    • Pry up on the two corners that are facing you with your fingers.
    • This may take a bit of force to open up and you will hear a fairly loud click when the bottom cover detaches.
    • Remove the bottom cover by sliding it towards the back corners and lifting up.
  4. PlayStation 4 Slim Optical Disc Drive Replacement, Power Supply: 4 단계, 이미지 1/3 PlayStation 4 Slim Optical Disc Drive Replacement, Power Supply: 4 단계, 이미지 2/3 PlayStation 4 Slim Optical Disc Drive Replacement, Power Supply: 4 단계, 이미지 3/3
    • Place the Playstation 4 Slim right side up, with the PS logo on top and the side with the words "SONY" and "PS4" facing you.
    • This may take a bit of force to open and you will hear a fairly loud click when the top cover detaches.
    • Remove the top cover by sliding it towards the back corners and lifting up.
  5. PlayStation 4 Slim Optical Disc Drive Replacement: 5 단계, 이미지 1/3 PlayStation 4 Slim Optical Disc Drive Replacement: 5 단계, 이미지 2/3 PlayStation 4 Slim Optical Disc Drive Replacement: 5 단계, 이미지 3/3
    • Unscrew and remove the two screws (left one 31.0mm and right one 24.0mm) using a T8 screwdriver with a counter-clockwise motion.
    • Unscrew and remove the 3.0mm screw using a Phillips #1 screwdriver with a counter-clockwise motion.
  6. PlayStation 4 Slim Optical Disc Drive Replacement: 6 단계, 이미지 1/1
    • Remove the four 16mm Philips screws holding the power supply in place.
  7. PlayStation 4 Slim Optical Disc Drive Replacement: 7 단계, 이미지 1/2 PlayStation 4 Slim Optical Disc Drive Replacement: 7 단계, 이미지 2/2
    • Remove the metal sheet from the top of the power supply by grabbing and lifting up with your hands.
  8. PlayStation 4 Slim Optical Disc Drive Replacement: 8 단계, 이미지 1/2 PlayStation 4 Slim Optical Disc Drive Replacement: 8 단계, 이미지 2/2
    • Remove the antenna from the top of the power supply by guiding the wire with your fingers through the groves underneath the metal panel.
  9. PlayStation 4 Slim Optical Disc Drive Replacement: 9 단계, 이미지 1/2 PlayStation 4 Slim Optical Disc Drive Replacement: 9 단계, 이미지 2/2
    • Flip the Playstation 4 Slim onto its back.
    • Unscrew and remove the 4.0mm screw using a Phillips #1 screwdriver with a counter-clockwise motion.
  10. PlayStation 4 Slim Optical Disc Drive Replacement: 10 단계, 이미지 1/3 PlayStation 4 Slim Optical Disc Drive Replacement: 10 단계, 이미지 2/3 PlayStation 4 Slim Optical Disc Drive Replacement: 10 단계, 이미지 3/3
    • Use a plastic opening tool to make space between the power supply and console by wedging and wiggling it in-between the two.
    • Lift the power supply up and onto its back on the metal sheet using your hands.
  11. PlayStation 4 Slim Optical Disc Drive Replacement: 11 단계, 이미지 1/3 PlayStation 4 Slim Optical Disc Drive Replacement: 11 단계, 이미지 2/3 PlayStation 4 Slim Optical Disc Drive Replacement: 11 단계, 이미지 3/3
    • Disconnect the wire connection from the power supply by firmly gripping it with your fingers or tweezers and pulling out.
    • Remove the power supply completely by grabbing and lifting up with your hands.
  12. PlayStation 4 Slim Optical Disc Drive Replacement, Optical Disc Drive: 12 단계, 이미지 1/2 PlayStation 4 Slim Optical Disc Drive Replacement, Optical Disc Drive: 12 단계, 이미지 2/2
    • Unscrew and remove the 31.0mm screw using a T8 screwdriver with a counter-clockwise motion.
    • Unscrew and remove the 10x 5.0mm screws using a Phillips #1 screwdriver with a counter-clockwise motion.
  13. PlayStation 4 Slim Optical Disc Drive Replacement: 13 단계, 이미지 1/2 PlayStation 4 Slim Optical Disc Drive Replacement: 13 단계, 이미지 2/2
    • Remove the metal plate by grabbing the edges and lifting up with your hands.
  14. PlayStation 4 Slim Optical Disc Drive Replacement: 14 단계, 이미지 1/2 PlayStation 4 Slim Optical Disc Drive Replacement: 14 단계, 이미지 2/2
    • Unscrew and remove the two 3.0mm screws using a PH000 screwdriver with a counter-clockwise motion.
  15. PlayStation 4 Slim Optical Disc Drive Replacement: 15 단계, 이미지 1/2 PlayStation 4 Slim Optical Disc Drive Replacement: 15 단계, 이미지 2/2
    • Remove the disk drive out by pinching on either side of the two black plastic "claws" and lifting up with your hand.
결론
다른 90명이 해당 안내서를 완성하였습니다.
Hernan Rodriguez
회원 가입일: 01/24/18
3,642 평판
안내서 3개 작성하였습니다
Cal Poly, Team S19-G4, Livingston Winter 2018 Cal Poly, Team S19-G4, Livingston Winter 2018 회원
CPSU-LIVINGSTON-W18S19G4
4 회원들
안내서 35개 작성하였습니다
댓글 24개
incomplete guide, what replacement? the last step is taking the cover off but what about the disk drive?
Yegor Ilchuk - 답글
Yeah, where's the ending to this?
Ben Baptist - 답글
To remove the complete drive you have to remove the motherboard. with the motherboard removed some of the above steps may not be necessary.
This guide is useful if you just need to remove disc or clean laser.
Freddie Parsons - 답글
when replacing do you have to swap a board like the PS4’s of the past?
Frank Ferrante - 답글
Nope, on the ps4 slim the optical drive is not married to the motherboard so any drive as long is the same model will work with any motherboard
Joshua Sites -
댓글 쓰기
조회 통계:
24 시간 전: 55
7일 전: 487
30일 전: 2,149
전체 시간: 172,015
