주요 콘텐츠로 건너뛰기
PlayStation 4 Slim Power Supply Replacement
필요한 것
  1. PlayStation 4 Slim Power Supply Replacement, Bottom Cover: 1 단계, 이미지 1/3 PlayStation 4 Slim Power Supply Replacement, Bottom Cover: 1 단계, 이미지 2/3 PlayStation 4 Slim Power Supply Replacement, Bottom Cover: 1 단계, 이미지 3/3
    • Locate the plastic warranty sticker next to the three ports on the side of the console.
    • Remove the warranty sticker by peeling it off with any kind of spudger.
    • Removing the warranty sticker will NOT cause your warranty to be null and void.
  2. PlayStation 4 Slim Power Supply Replacement: 2 단계, 이미지 1/2 PlayStation 4 Slim Power Supply Replacement: 2 단계, 이미지 2/2
    • Unscrew and remove the now exposed 5.0mm screw using a T8 security Torx screwdriver with a counter-clockwise motion.
  3. PlayStation 4 Slim Power Supply Replacement: 3 단계, 이미지 1/3 PlayStation 4 Slim Power Supply Replacement: 3 단계, 이미지 2/3 PlayStation 4 Slim Power Supply Replacement: 3 단계, 이미지 3/3
    • Place the Playstation 4 Slim upside down with the side of the screw you just removed facing you.
    • Pry up on the two corners that are facing you with your fingers.
    • This may take a bit of force to open up and you will hear a fairly loud click when the bottom cover detaches.
    • Remove the bottom cover by sliding it towards the back corners and lifting up.
  4. PlayStation 4 Slim Power Supply Replacement, Power Supply: 4 단계, 이미지 1/3 PlayStation 4 Slim Power Supply Replacement, Power Supply: 4 단계, 이미지 2/3 PlayStation 4 Slim Power Supply Replacement, Power Supply: 4 단계, 이미지 3/3
    • Place the Playstation 4 Slim right side up, with the PS logo on top and the side with the words "SONY" and "PS4" facing you.
    • This may take a bit of force to open and you will hear a fairly loud click when the top cover detaches.
    • Remove the top cover by sliding it towards the back corners and lifting up.
  5. PlayStation 4 Slim Power Supply Replacement: 5 단계, 이미지 1/3 PlayStation 4 Slim Power Supply Replacement: 5 단계, 이미지 2/3 PlayStation 4 Slim Power Supply Replacement: 5 단계, 이미지 3/3
    • Unscrew and remove the two screws (left one 31.0mm and right one 24.0mm) using a T8 screwdriver with a counter-clockwise motion.
    • Unscrew and remove the 3.0mm screw using a Phillips #1 screwdriver with a counter-clockwise motion.
  6. PlayStation 4 Slim Power Supply Replacement: 6 단계, 이미지 1/1
    • Remove the four 16mm Philips screws holding the power supply in place.
  7. PlayStation 4 Slim Power Supply Replacement: 7 단계, 이미지 1/2 PlayStation 4 Slim Power Supply Replacement: 7 단계, 이미지 2/2
    • Remove the metal sheet from the top of the power supply by grabbing and lifting up with your hands.
  8. PlayStation 4 Slim Power Supply Replacement: 8 단계, 이미지 1/2 PlayStation 4 Slim Power Supply Replacement: 8 단계, 이미지 2/2
    • Remove the antenna from the top of the power supply by guiding the wire with your fingers through the groves underneath the metal panel.
  9. PlayStation 4 Slim Power Supply Replacement: 9 단계, 이미지 1/2 PlayStation 4 Slim Power Supply Replacement: 9 단계, 이미지 2/2
    • Flip the Playstation 4 Slim onto its back.
    • Unscrew and remove the 4.0mm screw using a Phillips #1 screwdriver with a counter-clockwise motion.
  10. PlayStation 4 Slim Power Supply Replacement: 10 단계, 이미지 1/3 PlayStation 4 Slim Power Supply Replacement: 10 단계, 이미지 2/3 PlayStation 4 Slim Power Supply Replacement: 10 단계, 이미지 3/3
    • Use a plastic opening tool to make space between the power supply and console by wedging and wiggling it in-between the two.
    • Lift the power supply up and onto its back on the metal sheet using your hands.
  11. PlayStation 4 Slim Power Supply Replacement: 11 단계, 이미지 1/3 PlayStation 4 Slim Power Supply Replacement: 11 단계, 이미지 2/3 PlayStation 4 Slim Power Supply Replacement: 11 단계, 이미지 3/3
    • Disconnect the wire connection from the power supply by firmly gripping it with your fingers or tweezers and pulling out.
    • Remove the power supply completely by grabbing and lifting up with your hands.
결론
다른 70명이 해당 안내서를 완성하였습니다.
Hernan Rodriguez
회원 가입일: 01/24/18
3,642 평판
안내서 3개 작성하였습니다
Cal Poly, Team S19-G4, Livingston Winter 2018 Cal Poly, Team S19-G4, Livingston Winter 2018 회원
CPSU-LIVINGSTON-W18S19G4
4 회원들
안내서 35개 작성하였습니다
댓글 6개
Can the N15-160P1A power supply work on a PS4 system that originally came with N17-160P1A?
derasky4u - 답글
My PS4 not turning on
Khai Stering - 답글
This was awesome. Thanks for the assist
Christopher Gorgon - 답글
I need help figuring out what I did to my ps4 and what needs replacement I had the new nba 2k 22 in the disc drive and the game was partly finished downloading so as it was doing that I brought shinobi striker which I previously had to use someone’s account to play it so the game popped up as light so I deleted it the first time and redownloaded it and it still said lite so then I deleted again but this time I double tapped the PlayStation button and it went to Home Screen slowed down then froze so I unplugged it plugged it back up and it wouldn’t turn on
Deontay - 답글
My PS4 runs for 10 minutes and turns off again and again
HITESH MAKWANA - 답글
댓글 쓰기
조회 통계:
24 시간 전: 32
7일 전: 213
30일 전: 1,126
전체 시간: 92,729
