주요 콘텐츠로 건너뛰기
PlayStation 4 Turns On Then Back Off Repair
필요한 것
  1. PlayStation 4 Turns On Then Back Off Repair, Unplug & Remove Hard Drive Cover: 1 단계, 이미지 1/1
    • Unplug PS4 from all cables
    • Remove hard drive cover
  2. PlayStation 4 Turns On Then Back Off Repair, Remove Top Cover Screws: 2 단계, 이미지 1/2 PlayStation 4 Turns On Then Back Off Repair, Remove Top Cover Screws: 2 단계, 이미지 2/2
    • Remove two Torx T8 security screws from top cover.
    • Remove warranty sticker (if it's still there) and remove black screw for the top case using Torx T8 security screw.
  3. PlayStation 4 Turns On Then Back Off Repair, Remove Top Cover: 3 단계, 이미지 1/3 PlayStation 4 Turns On Then Back Off Repair, Remove Top Cover: 3 단계, 이미지 2/3 PlayStation 4 Turns On Then Back Off Repair, Remove Top Cover: 3 단계, 이미지 3/3
    • Pull up on front right edge of top cover.
    • After right front is loose pull up on left front.
    • Pull top cover back and set aside.
  4. PlayStation 4 Turns On Then Back Off Repair, Remove APU/Heat Sink Clamp Screws: 4 단계, 이미지 1/3 PlayStation 4 Turns On Then Back Off Repair, Remove APU/Heat Sink Clamp Screws: 4 단계, 이미지 2/3 PlayStation 4 Turns On Then Back Off Repair, Remove APU/Heat Sink Clamp Screws: 4 단계, 이미지 3/3
    • Using a Phillips PH1, remove two APU/heat sink clamp screws.
  5. PlayStation 4 Turns On Then Back Off Repair, Install Washers: 5 단계, 이미지 1/3 PlayStation 4 Turns On Then Back Off Repair, Install Washers: 5 단계, 이미지 2/3 PlayStation 4 Turns On Then Back Off Repair, Install Washers: 5 단계, 이미지 3/3
    • Start by installing 2 washers under each screw.
    • Install the clamp and screws and tighten screws.
  6. PlayStation 4 Turns On Then Back Off Repair, Plug PS4 In and Press Power Button: 6 단계, 이미지 1/3 PlayStation 4 Turns On Then Back Off Repair, Plug PS4 In and Press Power Button: 6 단계, 이미지 2/3 PlayStation 4 Turns On Then Back Off Repair, Plug PS4 In and Press Power Button: 6 단계, 이미지 3/3
    • Plug power cord into PS4.
    • Touch copper pad on PS4 to power on.
    • If PS4 powers on and stays on consider it fixed. If not, proceed to next step.
  7. PlayStation 4 Turns On Then Back Off Repair, Install 3rd Washer Under Each Screw: 7 단계, 이미지 1/2 PlayStation 4 Turns On Then Back Off Repair, Install 3rd Washer Under Each Screw: 7 단계, 이미지 2/2
    • If the PS4 still does not work after adding two washers you will then remove the heat sink clamp and add a third washer under each heat sink clamp screw.
  8. PlayStation 4 Turns On Then Back Off Repair, Power Console On: 8 단계, 이미지 1/2 PlayStation 4 Turns On Then Back Off Repair, Power Console On: 8 단계, 이미지 2/2
    • After third washer has been installed and the screws have been tightened touch the power pad on the motherboard.
    • If the PS4 makes no noise and shows no lights then the screws are too tight...loosen screws very slightly (about 1/8 turn) and try to power it on again. Do this until the console powers on.
    • If the console still turns on and back off after these steps have been done then this fix will not work for your PS4.
  9. PlayStation 4 Turns On Then Back Off Repair, IF ALL ELSE FAILS: 9 단계, 이미지 1/1
    • If your PS4 will not turn on (or turns on and right back off) after you have already had it working, try taking the cover back off and tighten the screws on the plate. If the screws are too tight the PS4 will not work at all. Slightly loosen until the system turns on. Be cautious about having the console plugged in. Possible but not recommended.
    • If you have your whole cover off of your PS4, and it is working properly, be sure to replace the cover. The cover is designed to distribute air from the fan and keep the system cool. It will cause it to turn off on its own if over heated.
결론
다른 56명이 해당 안내서를 완성하였습니다.
TronicsFix
회원 가입일: 11/06/13
34,900 평판
안내서 5개 작성하였습니다
TronicsFix TronicsFix 회원
Business
1 회원
안내서 21개 작성하였습니다
댓글 48개
Can't believe it worked! My PS4 has been sitting useless for so long and I felt to good when I did this today and it seemed completely normal again. We'll see if this works out over time or if it starts doing the same thing again. One thing I don't get is why they don't specify the washer size you'll need if you don't want to buy the entire kit, but I guess that's just marketing. Thus, I tore squares of glossy paper (a picture I had laying around) and poked them into the nails instead of washers. Works just as well for me!
Marco Arana - 답글
What size washers are needed for this
Rahan Ullah -
has this fixed your system permanently? did you have any problems since your last post?
tarnold844 -
and it will for a few day/weeks at most then it will fail again
ravendrow -
댓글 쓰기
조회 통계:
24 시간 전: 77
7일 전: 594
30일 전: 3,130
전체 시간: 473,656
