소개
Follow this guide to replace the Wi-Fi antenna on your Sony Playstation 4.
Unplug your PS4 before beginning any repairs.
Use tweezers to remove the two stickers in the center of the back of the PS4 exposing two case screws.
Use tweezers to carefully remove the plastic screw covers in each corner, exposing two more case screws.
Remove the four 7.2 mm Torx security screws on the back of the PS4.
Remove three 9.7 mm Torx security screws.
Remove two 41 mm Phillips screws and brackets.
Use the tip of a spudger to disconnect the antenna cable from the motherboard.
다른 75명이 해당 안내서를 완성하였습니다.
댓글 101개
Took me about 10mins with this guide. Super easy. New parts in and working wonderfully. Ty ifixit!
luckycha87 - 답글
My wireless controlers wasn't recognised. I change the WiFi connector but this problem is not resoleved yet.
Hi Frederic! Have you tried resetting the controller? Have you tried any other controllers to see if they work? Also, are you sure the battery in your controller is good and it's charged up?
Hello my controller has a hard time working from 4 feet away from my console and disconnecting. Im thinking of doing this hopefully it works. Is the bluetooth and wifi part the same thing because my wifi doesnt seem to pick up my wireless router.
Yes, the wifi and bluetooth antenna is the same.
