주요 콘텐츠로 건너뛰기
PlayStation 5 Faceplates Replacement
필요한 것
  1. PlayStation 5 Faceplates Replacement, Remove the stand screw: 1 단계, 이미지 1/1
    • If your PlayStation 5 is in its vertical orientation, flip it upside down so the stand is facing up.
    • If your PlayStation 5 is in its horizontal orientation, skip to Step 6.
    • Work on a flat surface to prevent your PlayStation from falling over.
    • Use a coin or a flathead screwdriver to remove the 26.5 mm-long stand screw.
  2. PlayStation 5 Faceplates Replacement, Remove the vertical stand: 2 단계, 이미지 1/2 PlayStation 5 Faceplates Replacement, Remove the vertical stand: 2 단계, 이미지 2/2
    • Lift straight up to remove the stand.
  3. PlayStation 5 Faceplates Replacement, Store the stand screw: 3 단계, 이미지 1/2 PlayStation 5 Faceplates Replacement, Store the stand screw: 3 단계, 이미지 2/2
    • Insert the screw into the cubby on the bottom of the stand.
  4. PlayStation 5 Faceplates Replacement, Cap the screw hole: 4 단계, 이미지 1/3 PlayStation 5 Faceplates Replacement, Cap the screw hole: 4 단계, 이미지 2/3 PlayStation 5 Faceplates Replacement, Cap the screw hole: 4 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use a pair of tweezers or your fingernail to remove the cap from the cubby.
    • Use your finger to press the cap into the screw hole.
  5. PlayStation 5 Faceplates Replacement, Close the cubby: 5 단계, 이미지 1/3 PlayStation 5 Faceplates Replacement, Close the cubby: 5 단계, 이미지 2/3 PlayStation 5 Faceplates Replacement, Close the cubby: 5 단계, 이미지 3/3
    • Twist the stand counterclockwise to close the cubby.
  6. PlayStation 5 Faceplates Replacement, Remove the horizontal stand: 6 단계, 이미지 1/2 PlayStation 5 Faceplates Replacement, Remove the horizontal stand: 6 단계, 이미지 2/2
    • If your PlayStation 5 is in its horizontal orientation, rest it on its face with the charging port facing up.
    • Lift the stand straight up to remove it.
  7. PlayStation 5 Faceplates Replacement, Remove the left faceplate: 7 단계, 이미지 1/3 PlayStation 5 Faceplates Replacement, Remove the left faceplate: 7 단계, 이미지 2/3 PlayStation 5 Faceplates Replacement, Remove the left faceplate: 7 단계, 이미지 3/3
    • Lift up the corner of the faceplate with the PlayStation logo to unclip it from the case.
  8. PlayStation 5 Faceplates Replacement: 8 단계, 이미지 1/2 PlayStation 5 Faceplates Replacement: 8 단계, 이미지 2/2
    • While lifting up the corner, slide the faceplate towards the bottom of the device.
    • Remove the left faceplate.
  9. PlayStation 5 Faceplates Replacement, Remove the right faceplate: 9 단계, 이미지 1/3 PlayStation 5 Faceplates Replacement, Remove the right faceplate: 9 단계, 이미지 2/3 PlayStation 5 Faceplates Replacement, Remove the right faceplate: 9 단계, 이미지 3/3
    • Flip the device over so that the USB and ethernet ports are on the left side from your perspective.
    • Lift up the corner of the faceplate to unclip it from the case.
  10. PlayStation 5 Faceplates Replacement: 10 단계, 이미지 1/2 PlayStation 5 Faceplates Replacement: 10 단계, 이미지 2/2
    • Remove the right faceplate.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our PlayStation 5 Answers community for help.
다른 14명이 해당 안내서를 완성하였습니다.
Clay Kim
회원 가입일: 02/16/21
9,922 평판
안내서 21개 작성하였습니다
댓글 한 개
Hello, thanks for the updates
hadi rp - 답글
댓글 쓰기
조회 통계:
24 시간 전: 20
7일 전: 181
30일 전: 958
전체 시간: 15,978
