주요 콘텐츠로 건너뛰기
PlayStation 5 Power Supply Replacement
필요한 것
  1. PlayStation 5 Power Supply Replacement, Remove the stand screw: 1 단계, 이미지 1개 중 1개
    • If your PlayStation 5 is in its vertical orientation, flip it upside down so the stand is facing up.
    • If your PlayStation 5 is in its horizontal orientation, skip to Step 6.
    • Work on a flat surface to prevent your PlayStation from falling over.
    • Use a coin or a flathead screwdriver to remove the 26.5 mm-long stand screw.
  2. PlayStation 5 Power Supply Replacement, Remove the vertical stand: 2 단계, 이미지 2개 중 1개 PlayStation 5 Power Supply Replacement, Remove the vertical stand: 2 단계, 이미지 2개 중 2개
    • Lift straight up to remove the stand.
  3. PlayStation 5 Power Supply Replacement, Store the stand screw: 3 단계, 이미지 2개 중 1개 PlayStation 5 Power Supply Replacement, Store the stand screw: 3 단계, 이미지 2개 중 2개
    • Insert the screw into the cubby on the bottom of the stand.
  4. PlayStation 5 Power Supply Replacement, Cap the screw hole: 4 단계, 이미지 3개 중 1개 PlayStation 5 Power Supply Replacement, Cap the screw hole: 4 단계, 이미지 3개 중 2개 PlayStation 5 Power Supply Replacement, Cap the screw hole: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use a pair of tweezers or your fingernail to remove the cap from the cubby.
    • Use your finger to press the cap into the screw hole.
  5. PlayStation 5 Power Supply Replacement, Close the cubby: 5 단계, 이미지 3개 중 1개 PlayStation 5 Power Supply Replacement, Close the cubby: 5 단계, 이미지 3개 중 2개 PlayStation 5 Power Supply Replacement, Close the cubby: 5 단계, 이미지 3개 중 3개
    • Twist the stand counterclockwise to close the cubby.
  6. PlayStation 5 Power Supply Replacement, Remove the horizontal stand: 6 단계, 이미지 2개 중 1개 PlayStation 5 Power Supply Replacement, Remove the horizontal stand: 6 단계, 이미지 2개 중 2개
    • If your PlayStation 5 is in its horizontal orientation, rest it on its face with the charging port facing up.
    • Lift the stand straight up to remove it.
  7. PlayStation 5 Power Supply Replacement, Remove the right faceplate: 7 단계, 이미지 3개 중 1개 PlayStation 5 Power Supply Replacement, Remove the right faceplate: 7 단계, 이미지 3개 중 2개 PlayStation 5 Power Supply Replacement, Remove the right faceplate: 7 단계, 이미지 3개 중 3개
    • Flip the device over so that the USB and ethernet ports are on the left side from your perspective.
    • Lift up the corner of the faceplate to unclip it from the case.
  8. PlayStation 5 Power Supply Replacement: 8 단계, 이미지 2개 중 1개 PlayStation 5 Power Supply Replacement: 8 단계, 이미지 2개 중 2개
    • While lifting up the corner, slide the faceplate towards the bottom of the device.
    • Remove the right faceplate.
  9. PlayStation 5 Power Supply Replacement, Pry up the grille: 9 단계, 이미지 3개 중 1개 PlayStation 5 Power Supply Replacement, Pry up the grille: 9 단계, 이미지 3개 중 2개 PlayStation 5 Power Supply Replacement, Pry up the grille: 9 단계, 이미지 3개 중 3개
    • Insert the flat end of a spudger underneath the grille and into the gap above the fan.
    • Lift up with the spudger to pry the grille away from the case.
  10. PlayStation 5 Power Supply Replacement, Remove the grille: 10 단계, 이미지 2개 중 1개 PlayStation 5 Power Supply Replacement, Remove the grille: 10 단계, 이미지 2개 중 2개
    • Lift the grille away from the case to remove it.
  11. PlayStation 5 Power Supply Replacement, Remove the fan shroud screws: 11 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    • Use a TR8 Torx security driver to remove the four screws securing the fan shroud to the case:
    • Two 23.3 mm-long screws
    • One 11.4 mm-long screw
    • One 31 mm-long screw
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
  12. PlayStation 5 Power Supply Replacement, Remove the fan shroud: 12 단계, 이미지 2개 중 1개 PlayStation 5 Power Supply Replacement, Remove the fan shroud: 12 단계, 이미지 2개 중 2개
    • Lift the fan shroud straight up to remove it.
  13. PlayStation 5 Power Supply Replacement, Remove the wire cover: 13 단계, 이미지 3개 중 1개 PlayStation 5 Power Supply Replacement, Remove the wire cover: 13 단계, 이미지 3개 중 2개 PlayStation 5 Power Supply Replacement, Remove the wire cover: 13 단계, 이미지 3개 중 3개
    • Insert the flat end of a spudger beneath the black wire cover and into the gap above the fan wires.
    • Pry only on the wire cover, not on the fan wires themselves.
    • Use the spudger to peel up the wire cover until you can grip it with your fingers.
  14. PlayStation 5 Power Supply Replacement: 14 단계, 이미지 3개 중 1개 PlayStation 5 Power Supply Replacement: 14 단계, 이미지 3개 중 2개 PlayStation 5 Power Supply Replacement: 14 단계, 이미지 3개 중 3개
    • Use your fingers to peel off the wire cover.
  15. PlayStation 5 Power Supply Replacement, Disconnect the fan: 15 단계, 이미지 2개 중 1개 PlayStation 5 Power Supply Replacement, Disconnect the fan: 15 단계, 이미지 2개 중 2개
    • Use your fingers to grip the edges of the fan cable connector, and pull up to disconnect it from the motherboard.
    • Always pull cables by their connectors and not the wires themselves.
  16. PlayStation 5 Power Supply Replacement, Remove the fan: 16 단계, 이미지 3개 중 1개 PlayStation 5 Power Supply Replacement, Remove the fan: 16 단계, 이미지 3개 중 2개 PlayStation 5 Power Supply Replacement, Remove the fan: 16 단계, 이미지 3개 중 3개
    • Lift the fan up and out of the case to remove it.
  17. PlayStation 5 Power Supply Replacement, Remove the SSD cover: 17 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the 17 mm-long SSD cover screw.
  18. PlayStation 5 Power Supply Replacement: 18 단계, 이미지 3개 중 1개 PlayStation 5 Power Supply Replacement: 18 단계, 이미지 3개 중 2개 PlayStation 5 Power Supply Replacement: 18 단계, 이미지 3개 중 3개
    • Use your finger to slide the SSD cover towards the top of the device to unclip it from the case.
    • Remove the SSD cover.
  19. PlayStation 5 Power Supply Replacement, Remove the optical drive wire: 19 단계, 이미지 2개 중 1개 PlayStation 5 Power Supply Replacement, Remove the optical drive wire: 19 단계, 이미지 2개 중 2개
    • Use your fingers to grip the edges of the optical drive cable connector, and pull up to disconnect it from the motherboard.
  20. PlayStation 5 Power Supply Replacement: 20 단계, 이미지 2개 중 1개 PlayStation 5 Power Supply Replacement: 20 단계, 이미지 2개 중 2개
    • Use your fingers to grip the edges of the optical drive cable connector, and pull up to disconnect it from the optical drive.
  21. PlayStation 5 Power Supply Replacement, Remove the tamper-evident sticker: 21 단계, 이미지 3개 중 1개 PlayStation 5 Power Supply Replacement, Remove the tamper-evident sticker: 21 단계, 이미지 3개 중 2개 PlayStation 5 Power Supply Replacement, Remove the tamper-evident sticker: 21 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to remove the tamper-evident sticker covering the remaining case screw.
    • If your PlayStation 5 hasn't been opened before, this sticker will be completely black. The pattern will appear after you remove it.
    • Technically, these are tamper-evident stickers—but don't worry—Sony can't legally void your warranty, as long as you don't damage anything. Have fun!
  22. PlayStation 5 Power Supply Replacement, Remove the case screws: 22 단계, 이미지 1개 중 1개
    • Use a T8 Torx driver to remove the eleven screws securing the case:
    • Six 18.6 mm-long screws
    • Two 43.2 mm-long screws
    • One 7.3 mm-long screw
  23. PlayStation 5 Power Supply Replacement, Remove the case: 23 단계, 이미지 2개 중 1개 PlayStation 5 Power Supply Replacement, Remove the case: 23 단계, 이미지 2개 중 2개
    • Lift the case straight up to remove it.
  24. PlayStation 5 Power Supply Replacement, Remove the optical drive ribbon cable: 24 단계, 이미지 3개 중 1개 PlayStation 5 Power Supply Replacement, Remove the optical drive ribbon cable: 24 단계, 이미지 3개 중 2개 PlayStation 5 Power Supply Replacement, Remove the optical drive ribbon cable: 24 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger to press down on the optical drive connector's metal locking tab.
    • With the metal tab depressed, use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the cable from the optical drive.
    • Pull only on the pull tab, not the cable itself.
  25. PlayStation 5 Power Supply Replacement, Remove the optical drive: 25 단계, 이미지 2개 중 1개 PlayStation 5 Power Supply Replacement, Remove the optical drive: 25 단계, 이미지 2개 중 2개
    • Lift the optical drive away from the device to remove it.
  26. PlayStation 5 Power Supply Replacement, Remove the optical drive ribbon cable: 26 단계, 이미지 3개 중 1개 PlayStation 5 Power Supply Replacement, Remove the optical drive ribbon cable: 26 단계, 이미지 3개 중 2개 PlayStation 5 Power Supply Replacement, Remove the optical drive ribbon cable: 26 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • With the metal tab depressed, use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the cable from the motherboard.
  27. PlayStation 5 Power Supply Replacement, Remove the power and eject button ribbon cable: 27 단계, 이미지 2개 중 1개 PlayStation 5 Power Supply Replacement, Remove the power and eject button ribbon cable: 27 단계, 이미지 2개 중 2개
    • Use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the power and eject button ribbon cable.
  28. PlayStation 5 Power Supply Replacement, Remove the LED ribbon cable: 28 단계, 이미지 2개 중 1개 PlayStation 5 Power Supply Replacement, Remove the LED ribbon cable: 28 단계, 이미지 2개 중 2개
    • Use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the LED ribbon cable.
  29. PlayStation 5 Power Supply Replacement, Remove the antenna wires: 29 단계, 이미지 3개 중 1개 PlayStation 5 Power Supply Replacement, Remove the antenna wires: 29 단계, 이미지 3개 중 2개 PlayStation 5 Power Supply Replacement, Remove the antenna wires: 29 단계, 이미지 3개 중 3개
    • Use a pair of tweezers to grip the white Wi-Fi antenna wire at its metal base, as close to the connector as possible.
    • Lift the wire's connector straight up to disconnect it from the motherboard.
    • Repeat for the black Wi-Fi antenna wire.
    • Some board revisions may not have these antenna wires. If your board is missing these connectors, skip this step.
  30. PlayStation 5 Power Supply Replacement: 30 단계, 이미지 3개 중 1개 PlayStation 5 Power Supply Replacement: 30 단계, 이미지 3개 중 2개 PlayStation 5 Power Supply Replacement: 30 단계, 이미지 3개 중 3개
    • Use a pair of tweezers to grip the black or blue power supply antenna wire at its metal base, as close to the connector as possible.
    • Repeat for the white power supply antenna wire.
  31. PlayStation 5 Power Supply Replacement, Remove the white stickers: 31 단계, 이미지 3개 중 1개 PlayStation 5 Power Supply Replacement, Remove the white stickers: 31 단계, 이미지 3개 중 2개 PlayStation 5 Power Supply Replacement, Remove the white stickers: 31 단계, 이미지 3개 중 3개
    • Use a pair of tweezers to peel back the white sticker holding the antenna wires to the top shield plate.
    • Remove the antenna wires from underneath the sticker.
    • Press the white sticker back down onto the top shield plate so it can be reused.
  32. PlayStation 5 Power Supply Replacement: 32 단계, 이미지 3개 중 1개 PlayStation 5 Power Supply Replacement: 32 단계, 이미지 3개 중 2개 PlayStation 5 Power Supply Replacement: 32 단계, 이미지 3개 중 3개
    • Repeat the previous step to peel back the four remaining stickers.
  33. PlayStation 5 Power Supply Replacement: 33 단계, 이미지 3개 중 1개 PlayStation 5 Power Supply Replacement: 33 단계, 이미지 3개 중 2개 PlayStation 5 Power Supply Replacement: 33 단계, 이미지 3개 중 3개
    • Use a pair of tweezers to peel back the white sticker holding the LED ribbon cable to the heat sink.
    • Remove the LED ribbon cable from underneath the sticker.
    • Press the white sticker back down onto the heat sink so it can be reused.
  34. PlayStation 5 Power Supply Replacement, Remove the top shield plate screws: 34 단계, 이미지 1개 중 1개
    • Use a T8 Torx driver to remove the forty-two screws securing the top shield plate:
    • Forty-one 7.3 mm-long screws
    • One 43.2 mm-long screw
  35. PlayStation 5 Power Supply Replacement, Remove the top shield plate: 35 단계, 이미지 3개 중 1개 PlayStation 5 Power Supply Replacement, Remove the top shield plate: 35 단계, 이미지 3개 중 2개 PlayStation 5 Power Supply Replacement, Remove the top shield plate: 35 단계, 이미지 3개 중 3개
    • Lift the top shield plate off of the motherboard to remove it.
    • During reassembly, this is a good point to replace any thermal pads on the top of the main board, if necessary. The pads may be stuck to both the top shield plate and the main board.
    • It's important that the replacement pads are the same thickness as the originals, otherwise the foam around the APU may not seal properly.
  36. PlayStation 5 Power Supply Replacement, Disconnect the USB board: 36 단계, 이미지 3개 중 1개 PlayStation 5 Power Supply Replacement, Disconnect the USB board: 36 단계, 이미지 3개 중 2개 PlayStation 5 Power Supply Replacement, Disconnect the USB board: 36 단계, 이미지 3개 중 3개
    • Use your finger to depress the metal locking tab on the USB board cable's board connector.
    • With the metal tab depressed, place the flat end of a spudger against the insulating foam pad on the ribbon cable and pull it directly away from the connector to disconnect it.
  37. PlayStation 5 Power Supply Replacement, Remove the left faceplate: 37 단계, 이미지 3개 중 1개 PlayStation 5 Power Supply Replacement, Remove the left faceplate: 37 단계, 이미지 3개 중 2개 PlayStation 5 Power Supply Replacement, Remove the left faceplate: 37 단계, 이미지 3개 중 3개
    • Lift up the corner of the faceplate with the PlayStation logo to unclip it from the case.
  38. PlayStation 5 Power Supply Replacement: 38 단계, 이미지 2개 중 1개 PlayStation 5 Power Supply Replacement: 38 단계, 이미지 2개 중 2개
    • Remove the left faceplate.
  39. PlayStation 5 Power Supply Replacement, Remove the screws: 39 단계, 이미지 1개 중 1개
    • Use a Torx T8 driver to remove the two 29.4 mm-long screws securing the case to the motherboard and heat sink assembly.
  40. PlayStation 5 Power Supply Replacement, Remove the case: 40 단계, 이미지 3개 중 1개 PlayStation 5 Power Supply Replacement, Remove the case: 40 단계, 이미지 3개 중 2개 PlayStation 5 Power Supply Replacement, Remove the case: 40 단계, 이미지 3개 중 3개
    • Lift the front edge of the case off of the motherboard and heat sink assembly.
    • With the front edge elevated, push the case back, away from the motherboard and heat sink assembly, to maneuver the charging port out of its slot in the case.
    • Remove the case.
    • The front plate may come apart from the plastic case. During reassembly, make sure the front plate is in place before reinserting the motherboard and power supply.
  41. PlayStation 5 Power Supply Replacement, Remove the power supply: 41 단계, 이미지 2개 중 1개 PlayStation 5 Power Supply Replacement, Remove the power supply: 41 단계, 이미지 2개 중 2개
    • Use a finger to hold the rear shield plate down against the work surface.
    • Grip the power supply and lift it straight up to disconnect it from the motherboard.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our PlayStation 5 Answers community for help.
다른 35명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Robert Boyd
회원 가입일: 02/01/21
29,298 평판
안내서 94개를 작성함
댓글 18개
Is there any place to buy a replacement power supply?
anon - 답글
Where can I get the power supply unit which is Model ADP-400DR ? Please help me
Addis - 답글
egamephone have ps5 power supply replacement
kasynlife -
So I started with a dead PS5. I had another power supply laying about but from a different revision. I replaced the power supply with said other power supply that works. When I put it back together still no power. Does each revision used a different power supply or would it be the same?
askanison420 - 답글
i’m having the same problem, did you ever get it to work?
abrey -
댓글 쓰기
조회 통계:
지난 24시간: 147
지난 7일: 873
지난 30일: 3,245
전체 시간: 134,480
