주요 콘텐츠로 건너뛰기
PlayStation 5 Power and Eject Button Board Replacement
필요한 것
  1. PlayStation 5 Power and Eject Button Board Replacement, Remove the stand screw: 1 단계, 이미지 1개 중 1개
    • If your PlayStation 5 is in its vertical orientation, flip it upside down so the stand is facing up.
    • If your PlayStation 5 is in its horizontal orientation, skip to Step 6.
    • Work on a flat surface to prevent your PlayStation from falling over.
    • Use a coin or a flathead screwdriver to remove the 26.5 mm-long stand screw.
  2. PlayStation 5 Power and Eject Button Board Replacement, Remove the vertical stand: 2 단계, 이미지 2개 중 1개 PlayStation 5 Power and Eject Button Board Replacement, Remove the vertical stand: 2 단계, 이미지 2개 중 2개
    • Lift straight up to remove the stand.
  3. PlayStation 5 Power and Eject Button Board Replacement, Store the stand screw: 3 단계, 이미지 2개 중 1개 PlayStation 5 Power and Eject Button Board Replacement, Store the stand screw: 3 단계, 이미지 2개 중 2개
    • Insert the screw into the cubby on the bottom of the stand.
  4. PlayStation 5 Power and Eject Button Board Replacement, Cap the screw hole: 4 단계, 이미지 3개 중 1개 PlayStation 5 Power and Eject Button Board Replacement, Cap the screw hole: 4 단계, 이미지 3개 중 2개 PlayStation 5 Power and Eject Button Board Replacement, Cap the screw hole: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use a pair of tweezers or your fingernail to remove the cap from the cubby.
    • Use your finger to press the cap into the screw hole.
  5. PlayStation 5 Power and Eject Button Board Replacement, Close the cubby: 5 단계, 이미지 3개 중 1개 PlayStation 5 Power and Eject Button Board Replacement, Close the cubby: 5 단계, 이미지 3개 중 2개 PlayStation 5 Power and Eject Button Board Replacement, Close the cubby: 5 단계, 이미지 3개 중 3개
    • Twist the stand counterclockwise to close the cubby.
  6. PlayStation 5 Power and Eject Button Board Replacement, Remove the horizontal stand: 6 단계, 이미지 2개 중 1개 PlayStation 5 Power and Eject Button Board Replacement, Remove the horizontal stand: 6 단계, 이미지 2개 중 2개
    • If your PlayStation 5 is in its horizontal orientation, rest it on its face with the charging port facing up.
    • Lift the stand straight up to remove it.
  7. PlayStation 5 Power and Eject Button Board Replacement, Remove the right faceplate: 7 단계, 이미지 3개 중 1개 PlayStation 5 Power and Eject Button Board Replacement, Remove the right faceplate: 7 단계, 이미지 3개 중 2개 PlayStation 5 Power and Eject Button Board Replacement, Remove the right faceplate: 7 단계, 이미지 3개 중 3개
    • Flip the device over so that the USB and ethernet ports are on the left side from your perspective.
    • Lift up the corner of the faceplate to unclip it from the case.
  8. PlayStation 5 Power and Eject Button Board Replacement: 8 단계, 이미지 2개 중 1개 PlayStation 5 Power and Eject Button Board Replacement: 8 단계, 이미지 2개 중 2개
    • While lifting up the corner, slide the faceplate towards the bottom of the device.
    • Remove the right faceplate.
  9. PlayStation 5 Power and Eject Button Board Replacement, Pry up the grille: 9 단계, 이미지 3개 중 1개 PlayStation 5 Power and Eject Button Board Replacement, Pry up the grille: 9 단계, 이미지 3개 중 2개 PlayStation 5 Power and Eject Button Board Replacement, Pry up the grille: 9 단계, 이미지 3개 중 3개
    • Insert the flat end of a spudger underneath the grille and into the gap above the fan.
    • Lift up with the spudger to pry the grille away from the case.
  10. PlayStation 5 Power and Eject Button Board Replacement, Remove the grille: 10 단계, 이미지 2개 중 1개 PlayStation 5 Power and Eject Button Board Replacement, Remove the grille: 10 단계, 이미지 2개 중 2개
    • Lift the grille away from the case to remove it.
  11. PlayStation 5 Power and Eject Button Board Replacement, Remove the fan shroud screws: 11 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    • Use a T9 Torx Security driver to remove the four screws securing the fan shroud to the case:
    • Two 23.3 mm-long screws
    • One 11.4 mm-long screw
    • One 31 mm-long screw
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
  12. PlayStation 5 Power and Eject Button Board Replacement, Remove the fan shroud: 12 단계, 이미지 2개 중 1개 PlayStation 5 Power and Eject Button Board Replacement, Remove the fan shroud: 12 단계, 이미지 2개 중 2개
    • Lift the fan shroud straight up to remove it.
  13. PlayStation 5 Power and Eject Button Board Replacement, Remove the wire cover: 13 단계, 이미지 3개 중 1개 PlayStation 5 Power and Eject Button Board Replacement, Remove the wire cover: 13 단계, 이미지 3개 중 2개 PlayStation 5 Power and Eject Button Board Replacement, Remove the wire cover: 13 단계, 이미지 3개 중 3개
    • Insert the flat end of a spudger beneath the black wire cover and into the gap above the fan wires.
    • Pry only on the wire cover, not on the fan wires themselves.
    • Use the spudger to peel up the wire cover until you can grip it with your fingers.
  14. PlayStation 5 Power and Eject Button Board Replacement: 14 단계, 이미지 3개 중 1개 PlayStation 5 Power and Eject Button Board Replacement: 14 단계, 이미지 3개 중 2개 PlayStation 5 Power and Eject Button Board Replacement: 14 단계, 이미지 3개 중 3개
    • Use your fingers to peel off the wire cover.
  15. PlayStation 5 Power and Eject Button Board Replacement, Disconnect the fan: 15 단계, 이미지 2개 중 1개 PlayStation 5 Power and Eject Button Board Replacement, Disconnect the fan: 15 단계, 이미지 2개 중 2개
    • Use your fingers to grip the edges of the fan cable connector, and pull up to disconnect it from the motherboard.
    • Always pull cables by their connectors and not the wires themselves.
  16. PlayStation 5 Power and Eject Button Board Replacement, Remove the fan: 16 단계, 이미지 3개 중 1개 PlayStation 5 Power and Eject Button Board Replacement, Remove the fan: 16 단계, 이미지 3개 중 2개 PlayStation 5 Power and Eject Button Board Replacement, Remove the fan: 16 단계, 이미지 3개 중 3개
    • Lift the fan up and out of the case to remove it.
  17. PlayStation 5 Power and Eject Button Board Replacement, Remove the SSD cover: 17 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the 17 mm-long SSD cover screw.
  18. PlayStation 5 Power and Eject Button Board Replacement: 18 단계, 이미지 3개 중 1개 PlayStation 5 Power and Eject Button Board Replacement: 18 단계, 이미지 3개 중 2개 PlayStation 5 Power and Eject Button Board Replacement: 18 단계, 이미지 3개 중 3개
    • Use your finger to slide the SSD cover towards the top of the device to unclip it from the case.
    • Remove the SSD cover.
  19. PlayStation 5 Power and Eject Button Board Replacement, Remove the optical drive wire: 19 단계, 이미지 2개 중 1개 PlayStation 5 Power and Eject Button Board Replacement, Remove the optical drive wire: 19 단계, 이미지 2개 중 2개
    • Use your fingers to grip the edges of the optical drive cable connector, and pull up to disconnect it from the motherboard.
  20. PlayStation 5 Power and Eject Button Board Replacement: 20 단계, 이미지 2개 중 1개 PlayStation 5 Power and Eject Button Board Replacement: 20 단계, 이미지 2개 중 2개
    • Use your fingers to grip the edges of the optical drive cable connector, and pull up to disconnect it from the optical drive.
  21. PlayStation 5 Power and Eject Button Board Replacement, Remove the tamper-evident sticker: 21 단계, 이미지 3개 중 1개 PlayStation 5 Power and Eject Button Board Replacement, Remove the tamper-evident sticker: 21 단계, 이미지 3개 중 2개 PlayStation 5 Power and Eject Button Board Replacement, Remove the tamper-evident sticker: 21 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to remove the tamper-evident sticker covering the remaining case screw.
    • If your PlayStation 5 hasn't been opened before, this sticker will be completely black. The pattern will appear after you remove it.
    • Technically, these are tamper-evident stickers—but don't worry—Sony can't legally void your warranty, as long as you don't damage anything. Have fun!
  22. PlayStation 5 Power and Eject Button Board Replacement, Remove the case screws: 22 단계, 이미지 1개 중 1개
    • Use a T8 Torx driver to remove the eleven screws securing the case:
    • Six 18.6 mm-long screws
    • Two 43.2 mm-long screws
    • One 7.3 mm-long screw
  23. PlayStation 5 Power and Eject Button Board Replacement, Remove the case: 23 단계, 이미지 2개 중 1개 PlayStation 5 Power and Eject Button Board Replacement, Remove the case: 23 단계, 이미지 2개 중 2개
    • Lift the case straight up to remove it.
  24. PlayStation 5 Power and Eject Button Board Replacement, Remove the optical drive ribbon cable: 24 단계, 이미지 3개 중 1개 PlayStation 5 Power and Eject Button Board Replacement, Remove the optical drive ribbon cable: 24 단계, 이미지 3개 중 2개 PlayStation 5 Power and Eject Button Board Replacement, Remove the optical drive ribbon cable: 24 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger to press down on the optical drive connector's metal locking tab.
    • With the metal tab depressed, use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the cable from the optical drive.
    • Pull only on the pull tab, not the cable itself.
  25. PlayStation 5 Power and Eject Button Board Replacement, Remove the optical drive: 25 단계, 이미지 2개 중 1개 PlayStation 5 Power and Eject Button Board Replacement, Remove the optical drive: 25 단계, 이미지 2개 중 2개
    • Lift the optical drive away from the device to remove it.
  26. PlayStation 5 Power and Eject Button Board Replacement, Remove the optical drive ribbon cable: 26 단계, 이미지 3개 중 1개 PlayStation 5 Power and Eject Button Board Replacement, Remove the optical drive ribbon cable: 26 단계, 이미지 3개 중 2개 PlayStation 5 Power and Eject Button Board Replacement, Remove the optical drive ribbon cable: 26 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • With the metal tab depressed, use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the cable from the motherboard.
  27. PlayStation 5 Power and Eject Button Board Replacement, Remove the power and eject button ribbon cable: 27 단계, 이미지 2개 중 1개 PlayStation 5 Power and Eject Button Board Replacement, Remove the power and eject button ribbon cable: 27 단계, 이미지 2개 중 2개
    • Use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the power and eject button ribbon cable.
  28. PlayStation 5 Power and Eject Button Board Replacement, Remove the LED ribbon cable: 28 단계, 이미지 2개 중 1개 PlayStation 5 Power and Eject Button Board Replacement, Remove the LED ribbon cable: 28 단계, 이미지 2개 중 2개
    • Use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the LED ribbon cable.
  29. PlayStation 5 Power and Eject Button Board Replacement, Remove the antenna wires: 29 단계, 이미지 3개 중 1개 PlayStation 5 Power and Eject Button Board Replacement, Remove the antenna wires: 29 단계, 이미지 3개 중 2개 PlayStation 5 Power and Eject Button Board Replacement, Remove the antenna wires: 29 단계, 이미지 3개 중 3개
    • Use a pair of tweezers to grip the white Wi-Fi antenna wire at its metal base, as close to the connector as possible.
    • Lift the wire's connector straight up to disconnect it from the motherboard.
    • Repeat for the black Wi-Fi antenna wire.
    • Some board revisions may not have these antenna wires. If your board is missing these connectors, skip this step.
  30. PlayStation 5 Power and Eject Button Board Replacement: 30 단계, 이미지 3개 중 1개 PlayStation 5 Power and Eject Button Board Replacement: 30 단계, 이미지 3개 중 2개 PlayStation 5 Power and Eject Button Board Replacement: 30 단계, 이미지 3개 중 3개
    • Use a pair of tweezers to grip the black or blue power supply antenna wire at its metal base, as close to the connector as possible.
    • Repeat for the white power supply antenna wire.
  31. PlayStation 5 Power and Eject Button Board Replacement, Remove the white stickers: 31 단계, 이미지 3개 중 1개 PlayStation 5 Power and Eject Button Board Replacement, Remove the white stickers: 31 단계, 이미지 3개 중 2개 PlayStation 5 Power and Eject Button Board Replacement, Remove the white stickers: 31 단계, 이미지 3개 중 3개
    • Use a pair of tweezers to peel back the white sticker holding the antenna wires to the top shield plate.
    • Remove the antenna wires from underneath the sticker.
    • Press the white sticker back down onto the top shield plate so it can be reused.
  32. PlayStation 5 Power and Eject Button Board Replacement: 32 단계, 이미지 3개 중 1개 PlayStation 5 Power and Eject Button Board Replacement: 32 단계, 이미지 3개 중 2개 PlayStation 5 Power and Eject Button Board Replacement: 32 단계, 이미지 3개 중 3개
    • Repeat the previous step to peel back the four remaining stickers.
  33. PlayStation 5 Power and Eject Button Board Replacement: 33 단계, 이미지 3개 중 1개 PlayStation 5 Power and Eject Button Board Replacement: 33 단계, 이미지 3개 중 2개 PlayStation 5 Power and Eject Button Board Replacement: 33 단계, 이미지 3개 중 3개
    • Use a pair of tweezers to peel back the white sticker holding the LED ribbon cable to the heat sink.
    • Remove the LED ribbon cable from underneath the sticker.
    • Press the white sticker back down onto the heat sink so it can be reused.
  34. PlayStation 5 Power and Eject Button Board Replacement, Remove the top shield plate screws: 34 단계, 이미지 1개 중 1개
    • Use a T8 Torx driver to remove the forty-two screws securing the top shield plate:
    • Forty-one 7.3 mm-long screws
    • One 43.2 mm-long screw
  35. PlayStation 5 Power and Eject Button Board Replacement, Remove the top shield plate: 35 단계, 이미지 3개 중 1개 PlayStation 5 Power and Eject Button Board Replacement, Remove the top shield plate: 35 단계, 이미지 3개 중 2개 PlayStation 5 Power and Eject Button Board Replacement, Remove the top shield plate: 35 단계, 이미지 3개 중 3개
    • Lift the top shield plate off of the motherboard to remove it.
    • During reassembly, this is a good point to replace any thermal pads on the top of the main board, if necessary. The pads may be stuck to both the top shield plate and the main board.
    • It's important that the replacement pads are the same thickness as the originals, otherwise the foam around the APU may not seal properly.
  36. PlayStation 5 Power and Eject Button Board Replacement, Disconnect the USB board: 36 단계, 이미지 3개 중 1개 PlayStation 5 Power and Eject Button Board Replacement, Disconnect the USB board: 36 단계, 이미지 3개 중 2개 PlayStation 5 Power and Eject Button Board Replacement, Disconnect the USB board: 36 단계, 이미지 3개 중 3개
    • Use your finger to depress the metal locking tab on the USB board cable's board connector.
    • With the metal tab depressed, place the flat end of a spudger against the insulating foam pad on the ribbon cable and pull it directly away from the connector to disconnect it.
  37. PlayStation 5 Power and Eject Button Board Replacement, Remove the left faceplate: 37 단계, 이미지 3개 중 1개 PlayStation 5 Power and Eject Button Board Replacement, Remove the left faceplate: 37 단계, 이미지 3개 중 2개 PlayStation 5 Power and Eject Button Board Replacement, Remove the left faceplate: 37 단계, 이미지 3개 중 3개
    • Lift up the corner of the faceplate with the PlayStation logo to unclip it from the case.
  38. PlayStation 5 Power and Eject Button Board Replacement: 38 단계, 이미지 2개 중 1개 PlayStation 5 Power and Eject Button Board Replacement: 38 단계, 이미지 2개 중 2개
    • Remove the left faceplate.
  39. PlayStation 5 Power and Eject Button Board Replacement, Remove the screws: 39 단계, 이미지 1개 중 1개
    • Use a Torx T8 driver to remove the two 29.4 mm-long screws securing the case to the motherboard and heat sink assembly.
  40. PlayStation 5 Power and Eject Button Board Replacement, Remove the case: 40 단계, 이미지 3개 중 1개 PlayStation 5 Power and Eject Button Board Replacement, Remove the case: 40 단계, 이미지 3개 중 2개 PlayStation 5 Power and Eject Button Board Replacement, Remove the case: 40 단계, 이미지 3개 중 3개
    • Lift the front edge of the case off of the motherboard and heat sink assembly.
    • With the front edge elevated, push the case back, away from the motherboard and heat sink assembly, to maneuver the charging port out of its slot in the case.
    • Remove the case.
    • The front plate may come apart from the plastic case. During reassembly, make sure the front plate is in place before reinserting the motherboard and power supply.
  41. PlayStation 5 Power and Eject Button Board Replacement, Remove the middle panel: 41 단계, 이미지 2개 중 1개 PlayStation 5 Power and Eject Button Board Replacement, Remove the middle panel: 41 단계, 이미지 2개 중 2개
    • Lift up to remove the middle panel from the case.
  42. PlayStation 5 Power and Eject Button Board Replacement, Remove the screws: 42 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the two 6.5 mm-long screws securing the power and eject button board to the middle panel.
  43. PlayStation 5 Power and Eject Button Board Replacement, Remove the power and eject button board: 43 단계, 이미지 2개 중 1개 PlayStation 5 Power and Eject Button Board Replacement, Remove the power and eject button board: 43 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to remove the power and eject button board from the middle panel.
  44. PlayStation 5 Power and Eject Button Board Replacement: 44 단계, 이미지 2개 중 1개 PlayStation 5 Power and Eject Button Board Replacement: 44 단계, 이미지 2개 중 2개
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our PlayStation 5 Answers community for help.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Robert Boyd
회원 가입일: 02/01/21
31,676 평판
안내서 94개를 작성함
2가이드 댓글
Apart from having two buttons (power and eject) are the button boards different in the digital edition vs Blu-ray edition?
SimonLondon - 답글
The original PS5 (pre 2021 models) use the same size board for both Digital and Blu-ray consoles, so yes, the board will fit both models (the eject button will be redundant on a Digital Edition) - they are available here: https://consoletherapy.com/playstation-5...
James H - 답글
댓글 쓰기
조회 통계:
지난 24시간: 11
지난 7일: 96
지난 30일: 304
전체 시간: 10,451
