주요 콘텐츠로 건너뛰기
PlayStation Controller Ports Replacement
필요한 것
  1. PlayStation Controller Ports Replacement, Open the Console: 1 단계, 이미지 1/1
    • Before you begin, make sure the console is turned off and unplugged.
    • Turn the console upside down and remove the five 15.8 mm-long Phillips #1 screws.
    The SCPH-9001 model does not have the Parallel Port panel to remove.
    Aislinn - 답글
  2. PlayStation Controller Ports Replacement: 2 단계, 이미지 1/2 PlayStation Controller Ports Replacement: 2 단계, 이미지 2/2
    • While holding the top and bottom halves of the console together, flip the console back over. Lift the top cover straight up to remove it.
  3. PlayStation Controller Ports Replacement, Remove the Controller Ports: 3 단계, 이미지 1/1
    • Remove five Phillips #1 screws securing the metal shield to the controller ports:
    • Two 14 mm screws
    • Three 8 mm screws
  4. PlayStation Controller Ports Replacement: 4 단계, 이미지 1/2 PlayStation Controller Ports Replacement: 4 단계, 이미지 2/2
    • Lift the metal shield straight up to remove it.
  5. PlayStation Controller Ports Replacement: 5 단계, 이미지 1/2 PlayStation Controller Ports Replacement: 5 단계, 이미지 2/2
    • Pull the controller port's ribbon cable straight up and out of its socket on the motherboard to disconnect it.
  6. PlayStation Controller Ports Replacement: 6 단계, 이미지 1/2 PlayStation Controller Ports Replacement: 6 단계, 이미지 2/2
    • Lift the controller ports straight up and out of the bottom case.
결론
다른 11명이 해당 안내서를 완성하였습니다.
Craig Lloyd
회원 가입일: 02/10/16
35,418 평판
안내서 82개 작성하였습니다
댓글 5개
I try replacing the controller and still wouldn't play memory cards.
redevil19 - 답글
I changed the controller port but the psx still doesn't recognize any controller. Both controller port and ribbon cable work perfect in other console. I wonder which components on the mother board are related with the controller ports so I can check them with a tester.
Daniel Prieto - 답글
I replaced the PS605 fuse and now the controllers work again! Thanks to this video https://www.youtube.com/watch?v=HdULot5F...
Daniel Prieto -
I'm having a weird issue, it will read in second do
Port but not the first. Changed controller port and still having the same issue
michael wise - 답글
The problem on mine is where I can’t use memory card slot 1 but Slot 2 works and is what I use but I would like to used slot 1 and have more than just a single memory card for playing games on it.
Travirus - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 32
30일 전: 150
전체 시간: 26,368
