주요 콘텐츠로 건너뛰기
PlayStation Motherboard Replacement
필요한 것
  1. PlayStation Motherboard Replacement, Open the Console: 1 단계, 이미지 1/1
    • Before you begin, make sure the console is turned off and unplugged.
    • Turn the console upside down and remove the five 15.8 mm-long Phillips #1 screws.
  2. PlayStation Motherboard Replacement: 2 단계, 이미지 1/2 PlayStation Motherboard Replacement: 2 단계, 이미지 2/2
    • While holding the top and bottom halves of the console together, flip the console back over. Lift the top cover straight up to remove it.
  3. PlayStation Motherboard Replacement, Remove the Controller Ports: 3 단계, 이미지 1/1
    • Remove five Phillips #1 screws securing the metal shield to the controller ports:
    • Two 14 mm screws
    • Three 8 mm screws
  4. PlayStation Motherboard Replacement: 4 단계, 이미지 1/2 PlayStation Motherboard Replacement: 4 단계, 이미지 2/2
    • Lift the metal shield straight up to remove it.
  5. PlayStation Motherboard Replacement: 5 단계, 이미지 1/2 PlayStation Motherboard Replacement: 5 단계, 이미지 2/2
    • Pull the controller port's ribbon cable straight up and out of its socket on the motherboard to disconnect it.
  6. PlayStation Motherboard Replacement: 6 단계, 이미지 1/2 PlayStation Motherboard Replacement: 6 단계, 이미지 2/2
    • Lift the controller ports straight up and out of the bottom case.
  7. PlayStation Motherboard Replacement, Remove the Optical Drive: 7 단계, 이미지 1/2 PlayStation Motherboard Replacement, Remove the Optical Drive: 7 단계, 이미지 2/2
    • Pull the optical drive power cable straight up and out of its socket on the motherboard to disconnect it.
  8. PlayStation Motherboard Replacement: 8 단계, 이미지 1/3 PlayStation Motherboard Replacement: 8 단계, 이미지 2/3 PlayStation Motherboard Replacement: 8 단계, 이미지 3/3
    • Use the flat end of a spudger to lift up and unlock one side of the data cable's connector on the motherboard. Repeat this step on the other side of the connector.
    • You'll hear a faint click noise when unlocking the connector. Make sure not to apply too much pressure when lifting up on the connector with the spudger, or else damage may result.
    • Gently pull the optical drive data cable straight up and out of its socket on the motherboard to disconnect it.
  9. PlayStation Motherboard Replacement: 9 단계, 이미지 1/2 PlayStation Motherboard Replacement: 9 단계, 이미지 2/2
    • Lift the optical drive straight up to remove it.
  10. PlayStation Motherboard Replacement, Unplug the Power Supply: 10 단계, 이미지 1/2 PlayStation Motherboard Replacement, Unplug the Power Supply: 10 단계, 이미지 2/2
    • Pull the power supply cable straight up and out of its socket on the motherboard to disconnect it.
  11. PlayStation Motherboard Replacement, Remove the Motherboard's Metal Shield: 11 단계, 이미지 1/1
    • Remove the five 14 mm-long Phillips #1 screws from the motherboard's metal shield.
  12. PlayStation Motherboard Replacement: 12 단계, 이미지 1/3 PlayStation Motherboard Replacement: 12 단계, 이미지 2/3 PlayStation Motherboard Replacement: 12 단계, 이미지 3/3
    • From the left side, lift up the metal shield and rotate it about its right edge, opening it like a book.
    • There may be strips of tape holding the right side of the metal shield to the case, necessitating this kind of removal procedure. If there isn't tape, you can simply lift the shield straight up to remove it.
  13. PlayStation Motherboard Replacement, Remove the Motherboard: 13 단계, 이미지 1/1
    • Remove the three 14 mm-long Phillips #1 screws securing the motherboard to the bottom case.
  14. PlayStation Motherboard Replacement: 14 단계, 이미지 1/2 PlayStation Motherboard Replacement: 14 단계, 이미지 2/2
    • Lift the motherboard out of the bottom case.
결론
다른 27명이 해당 안내서를 완성하였습니다.
Craig Lloyd
회원 가입일: 02/10/16
35,423 평판
안내서 82개 작성하였습니다
댓글 2개
Hi there.
Here i can buy that copper tape from the right of the metal shield ?
Thkx in adv
Haitham - 답글
Excelente guía, esto ayuda a muchos para aprender a reparar y no hacer gastos innecesarios.
aldrin peñate - 답글
댓글 쓰기
조회 통계:
24 시간 전: 12
7일 전: 49
30일 전: 203
전체 시간: 26,022
