이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This will guide you through the process of replacing your logic board.
필요한 것
Turn the console upside down and remove the five 15.8 mm-long Phillips #1 screws.
Pull the optical drive power cable straight up and out of its socket on the motherboard to disconnect it.
With one hand, hold the main board’s protective metal cover. With your other hand, wedge the spudger in between the right side of the protective cover and the thin metal clamps that surround it.
With the spudger in place, gently lift the upper portion of the metal cover. The cover should detach from the right side.
다른 27명이 해당 안내서를 완성하였습니다.
댓글 2개
Excelente guía, esto ayuda a muchos para aprender a reparar y no hacer gastos innecesarios.
