주요 콘텐츠로 건너뛰기
소개
This guide will show the steps to dismantle the move controller and remove the battery in order to have it replaced.
  1. Using a Phillips #0 screwdriver, remove the  four 10mm screws from the corners of the trigger button.
    • Using a Phillips #0 screwdriver, remove the four 10mm screws from the corners of the trigger button.
    Which screws are these? Didn’t have them on mine (CECH-ZCM1E) so I skipped straight to step 2.
    Dan Rushton - 답글
  2. Using a Phillips #0 screwdriver,  remove the four 10mm screws located at the back of the device. Using a Phillips #0 screwdriver,  remove the four 10mm screws located at the back of the device. Using a Phillips #0 screwdriver,  remove the four 10mm screws located at the back of the device.
    • Using a Phillips #0 screwdriver, remove the four 10mm screws located at the back of the device.
  3. Insert the plastic opening tool at the indent along the front and back surfaces of the controller. Gently use a forward and backward motion to safely pop open the cover.
    • Insert the plastic opening tool at the indent along the front and back surfaces of the controller.
    • Gently use a forward and backward motion to safely pop open the cover.
    • Use your hands to further pull it apart and pop it open.
  4. 안드로이드 수리 키트
    A new screen or battery is one kit away.
    지금 장보기
    안드로이드 수리 키트
    지금 장보기
  5. Once the device is opened, lift the battery out of the black plastic holder. Carefully pull the battery out and ensure that it's wires are still connected to the inside.
    • Once the device is opened, lift the battery out of the black plastic holder.
    • Carefully pull the battery out and ensure that it's wires are still connected to the inside.
    You can disconnect the back/trigger assembly ribbon cable at this point by proceeding to Steps 13/14 (without the other steps for disassembly as they are unnecessary for replacing just the trigger).
    Peter Miller - 답글
  6. Using a Phillips head screwdriver, remove the 9mm screw located to the right of the battery, which is connected to  the inner plastic frame. Use the plastic opening tool to carefully take out the grey cylindrical piece (vibrator) that is also attached to a wire. Use the plastic opening tool to carefully take out the grey cylindrical piece (vibrator) that is also attached to a wire.
    • Using a Phillips head screwdriver, remove the 9mm screw located to the right of the battery, which is connected to the inner plastic frame.
    • Use the plastic opening tool to carefully take out the grey cylindrical piece (vibrator) that is also attached to a wire.
  7. Gently pull out the small cylindrical grey piece (vibrator). Removing this piece makes it easier to access the wire connection of the battery and remove it.
    • Gently pull out the small cylindrical grey piece (vibrator).
    • Removing this piece makes it easier to access the wire connection of the battery and remove it.
  8. Use tweezers  to remove the small piece with a cylindrical top that is located to the left of the inner plastic frame. Use tweezers  to remove the small piece with a cylindrical top that is located to the left of the inner plastic frame.
    • Use tweezers to remove the small piece with a cylindrical top that is located to the left of the inner plastic frame.
  9. Use one hand to hold the bottom of the device, and the other hand to squeeze the inner plastic frame. While squeezing the inner plastic frame, pull it up and then pull it towards you to detach it. While removing the frame, be extremely careful because it could damage the frame or the motherboard.
    • Use one hand to hold the bottom of the device, and the other hand to squeeze the inner plastic frame.
    • While squeezing the inner plastic frame, pull it up and then pull it towards you to detach it.
    • While removing the frame, be extremely careful because it could damage the frame or the motherboard.
  10. Gently pull on the end of the red and black wires which is closest to the connector to disconnect the battery. Gently pull on the end of the red and black wires which is closest to the connector to disconnect the battery.
    • Gently pull on the end of the red and black wires which is closest to the connector to disconnect the battery.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Jenelle Mohammed
회원 가입일: 2016년 09월 28일
157 평판
안내서 1개 작성함
USF Tampa, Team 3-3, Passmore Fall 2016 USF Tampa, Team 3-3, Passmore Fall 2016 회원
USFT-PASSMORE-F16S3G3
4 회원들
안내서 4개 작성하였습니다
When putting the plastic battery rig back in on my second time doing this, I bent one of the little plastic pins that fits into a hole in the PCB. Definitely want to be careful with that. To make it a bit easier, I unscrewed the bottom port PCB part of the way so I could take the bottom plastic housing and put the plastic battery rig in straight. It made it a lot easier.
Burke Cates - 답글
No need to take out the motor, just use sharp tweezers and grab the connector (NOT the wires) and with small wiggling pull it out. Worked for mine.
crus - 답글
Worked great! Thanks for this. I did not need to take out the black battery / motor piece. Tweezers worked great to remove and install the battery cable
Harry Skigis - 답글
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 36
지난 30일: 156
전체 시간: 4,760
