이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
The USB is an important part of the PlayStation Move controller. This guide will help you to remove and replace.
필요한 것
At the end of the circuit board, you should see a small silver connector port (this is the USB).
Using a soldering iron, carefully desolder the port from the board. For help with desoldering, please reference this guide: How To Solder and Desolder Connections
다른 2명이 해당 안내서를 완성하였습니다.
