주요 콘텐츠로 건너뛰기
PlayStation One Lower Case Replacement
필요한 것
  1. PlayStation One Lower Case Replacement, Upper Case: 1 단계, 이미지 1/1
    • Remove all cables plugged into the PlayStation.
  2. PlayStation One Lower Case Replacement: 2 단계, 이미지 1/2 PlayStation One Lower Case Replacement: 2 단계, 이미지 2/2
    • Flip over the PlayStation and remove the six screws from the bottom.
  3. PlayStation One Lower Case Replacement: 3 단계, 이미지 1/1
    • Flip the PlayStation back.
    • There are no screws holding EVERYTHING inside the PlayStation so better hold it like a burger while flipping.
  4. PlayStation One Lower Case Replacement: 4 단계, 이미지 1/2 PlayStation One Lower Case Replacement: 4 단계, 이미지 2/2
    • Lift up and remove the upper case.
  5. PlayStation One Lower Case Replacement, Laser Assembly: 5 단계, 이미지 1/3 PlayStation One Lower Case Replacement, Laser Assembly: 5 단계, 이미지 2/3 PlayStation One Lower Case Replacement, Laser Assembly: 5 단계, 이미지 3/3
    • Disconnect the cables from the PSone’s board.
    • Take extreme care when disconnecting the ribbon cable from motherboard. You risk damaging the cable if you’re not careful.
  6. PlayStation One Lower Case Replacement, Mother Board: 6 단계, 이미지 1/2 PlayStation One Lower Case Replacement, Mother Board: 6 단계, 이미지 2/2
    • remove the metal plate
  7. PlayStation One Lower Case Replacement: 7 단계, 이미지 1/3 PlayStation One Lower Case Replacement: 7 단계, 이미지 2/3 PlayStation One Lower Case Replacement: 7 단계, 이미지 3/3
    • remove the mother board by lifting the back.
    • if you're having a hard time removing it, use your nail and lift the second controller port.
  8. PlayStation One Lower Case Replacement, Lower Case: 8 단계, 이미지 1/2 PlayStation One Lower Case Replacement, Lower Case: 8 단계, 이미지 2/2
    • Remove the metal case.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Marjorie
회원 가입일: 12/23/13
2,273 평판
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 15
30일 전: 58
전체 시간: 3,994
