주요 콘텐츠로 건너뛰기
PlayStation One Mother Board Replacement
필요한 것
  1. PlayStation One Mother Board Replacement, Upper Case: 1 단계, 이미지 1/1
    • Remove all cables plugged into the PlayStation.
  2. PlayStation One Mother Board Replacement: 2 단계, 이미지 1/2 PlayStation One Mother Board Replacement: 2 단계, 이미지 2/2
    • Flip over the PlayStation and remove the six screws from the bottom.
  3. PlayStation One Mother Board Replacement: 3 단계, 이미지 1/1
    • Flip the PlayStation back.
    • There are no screws holding EVERYTHING inside the PlayStation so better hold it like a burger while flipping.
  4. PlayStation One Mother Board Replacement: 4 단계, 이미지 1/2 PlayStation One Mother Board Replacement: 4 단계, 이미지 2/2
    • Lift up and remove the upper case.
  5. PlayStation One Mother Board Replacement, Laser Assembly: 5 단계, 이미지 1/3 PlayStation One Mother Board Replacement, Laser Assembly: 5 단계, 이미지 2/3 PlayStation One Mother Board Replacement, Laser Assembly: 5 단계, 이미지 3/3
    • Disconnect the cables from the PSone’s board.
    • Take extreme care when disconnecting the ribbon cable from motherboard. You risk damaging the cable if you’re not careful.
  6. PlayStation One Mother Board Replacement, Mother Board: 6 단계, 이미지 1/2 PlayStation One Mother Board Replacement, Mother Board: 6 단계, 이미지 2/2
    • remove the metal plate
    well well a modded ps one hahah
    Bernabe Alvarez - 답글
  7. PlayStation One Mother Board Replacement: 7 단계, 이미지 1/3 PlayStation One Mother Board Replacement: 7 단계, 이미지 2/3 PlayStation One Mother Board Replacement: 7 단계, 이미지 3/3
    • remove the mother board by lifting the back.
    • if you're having a hard time removing it, use your nail and lift the second controller port.
결론
다른 14명이 해당 안내서를 완성하였습니다.
Marjorie
회원 가입일: 12/23/13
2,273 평판
안내서 11개 작성하였습니다
댓글 한 개
I think that the GPU in my PS One is going bad (screen flickers green and pink on occasion but it is becoming more frequent). Would replacing the motherboard fix this? That is, is the GPU stored on the motherboard?
Eric Rosenberg - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 23
30일 전: 140
전체 시간: 11,314
