주요 콘텐츠로 건너뛰기
PlayStation Power Supply Replacement
필요한 것
  1. PlayStation Power Supply Replacement, Open the Console: 1 단계, 이미지 1개 중 1개
    • Before you begin, make sure the console is turned off and unplugged.
    • Turn the console upside down and remove the five 15.8 mm-long Phillips #1 screws.
  2. PlayStation Power Supply Replacement: 2 단계, 이미지 2개 중 1개 PlayStation Power Supply Replacement: 2 단계, 이미지 2개 중 2개
    • While holding the top and bottom halves of the console together, flip the console back over. Lift the top cover straight up to remove it.
  3. PlayStation Power Supply Replacement, Unplug the Power Supply: 3 단계, 이미지 2개 중 1개 PlayStation Power Supply Replacement, Unplug the Power Supply: 3 단계, 이미지 2개 중 2개
    • Pull the power supply cable straight up and out of its socket on the power supply to disconnect it.
  4. PlayStation Power Supply Replacement, Remove the Power Supply: 4 단계, 이미지 1개 중 1개
    • Remove the two 14 mm-long Phillips #1 screws securing the power supply to the bottom case.
  5. PlayStation Power Supply Replacement: 5 단계, 이미지 2개 중 1개 PlayStation Power Supply Replacement: 5 단계, 이미지 2개 중 2개
    • Lift the outer edge of the power supply slightly, then rotate the whole power supply away from the small clip on its inner edge to remove the power supply.
결론
다른 25명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Craig Lloyd
회원 가입일: 02/10/16
38,815 평판
안내서 82개를 작성함
댓글 4개
Since working with the power supply, it's wise to state in writing to disconnect the AC cord, in addition to showing it disconnected as you have.
Collin - 답글
Once I take out my power supply how do I fix the issue with the power supply
Tiago - 답글
im done removing the power supply so whats next???btw i accidentally plugged my ps1 110v to 220v how to fix that issue???
kendofox - 답글
Before anything unplug your PlayStation and try the power button couple a times to turn on the PlayStation.
Just check the fuse with a multimeter. It is a cylindrical tube with metal on it’s two corners. The easy way is to check continuity with a mutimeter which is a symbol with a speaker on it. Touch red and black probes and you will hear a beep. Connect the two ends of the fuse and if it beeps then fuse is ok. You can even check it while fuse is on the board. If ok and PlayStation is not working then there is a problem somewhere else on the power board, mostly…
Good Luck!!
gUru0026 -
댓글 쓰기
조회 통계:
지난 24시간: 13
지난 7일: 52
지난 30일: 184
전체 시간: 28,139
