주요 콘텐츠로 건너뛰기
PlayStation TV Thermal Pad Replacement
필요한 것
  1. PlayStation TV Thermal Pad Replacement, Motherboard: 1 단계, 이미지 1/2 PlayStation TV Thermal Pad Replacement, Motherboard: 1 단계, 이미지 2/2
    • Use the plastic spudger to pry up the bottom piece of the case to release the clips.
  2. PlayStation TV Thermal Pad Replacement: 2 단계, 이미지 1/2 PlayStation TV Thermal Pad Replacement: 2 단계, 이미지 2/2
    • Remove the four 6 mm Phillips screws.
    • Remove the two Phillips #0 screws.
  3. PlayStation TV Thermal Pad Replacement: 3 단계, 이미지 1/2 PlayStation TV Thermal Pad Replacement: 3 단계, 이미지 2/2
    • Remove the heat shield using the plastic opening tool.
    • Slide the tool around the edges until the shield is free.
  4. PlayStation TV Thermal Pad Replacement: 4 단계, 이미지 1/2 PlayStation TV Thermal Pad Replacement: 4 단계, 이미지 2/2
    • Remove the last 6mm Phillips #0 screw from the motherboard.
  5. PlayStation TV Thermal Pad Replacement: 5 단계, 이미지 1/2 PlayStation TV Thermal Pad Replacement: 5 단계, 이미지 2/2
    • Use a plastic opening tool to pry up gently on the motherboard, and remove it.
  6. PlayStation TV Thermal Pad Replacement, Thermal Pad: 6 단계, 이미지 1/2 PlayStation TV Thermal Pad Replacement, Thermal Pad: 6 단계, 이미지 2/2
    • Remove the old thermal pad with an ESD safe tool, like a Jimmy.
  7. PlayStation TV Thermal Pad Replacement: 7 단계, 이미지 1/2 PlayStation TV Thermal Pad Replacement: 7 단계, 이미지 2/2
    • Wipe down the area where the old thermal pads were located with rubbing alcohol.
    • It is important that the area be as clean as possible.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Theodore Hesse
회원 가입일: 01/22/16
145 평판
안내서 1개 작성함
IUPUI, Team 3-1, Baechle Spring 2016 IUPUI, Team 3-1, Baechle Spring 2016 회원
IUPUI-BAECHLE-S16S3G1
4 회원들
안내서 4개 작성하였습니다
댓글 2개
Photos for steps 6 through 9 will be posted soon!
Luk Davis - 답글
Do you replace the thermal pad? Your directions do not state where to do this, and if so what part and size do you recommend?
Daimonion - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 31
전체 시간: 1,848
