주요 콘텐츠로 건너뛰기
PlayStation VR Processor Unit Cooling Fan Replacement
필요한 것
  1. PlayStation VR Processor Unit Cooling Fan Replacement, Processor Unit Cooling Fan: 1 단계, 이미지 1/3 PlayStation VR Processor Unit Cooling Fan Replacement, Processor Unit Cooling Fan: 1 단계, 이미지 2/3 PlayStation VR Processor Unit Cooling Fan Replacement, Processor Unit Cooling Fan: 1 단계, 이미지 3/3
    • On one side of the console (the side adjacent to the fan vent), there will be two 6 mm screws. Unscrew them with a PH #000 screwdriver.
  2. PlayStation VR Processor Unit Cooling Fan Replacement: 2 단계, 이미지 1/3 PlayStation VR Processor Unit Cooling Fan Replacement: 2 단계, 이미지 2/3 PlayStation VR Processor Unit Cooling Fan Replacement: 2 단계, 이미지 3/3
    • Press and slide the side panel (it will have the two ports) back to reveal an additional 6 mm screw.
    • Unscrew the 6mm screw with a PH #000 screwdriver.
  3. PlayStation VR Processor Unit Cooling Fan Replacement: 3 단계, 이미지 1/2 PlayStation VR Processor Unit Cooling Fan Replacement: 3 단계, 이미지 2/2
    • Slide the panel back into place.
  4. PlayStation VR Processor Unit Cooling Fan Replacement: 4 단계, 이미지 1/3 PlayStation VR Processor Unit Cooling Fan Replacement: 4 단계, 이미지 2/3 PlayStation VR Processor Unit Cooling Fan Replacement: 4 단계, 이미지 3/3
    • Using a plastic opening tool, carefully pry the panel from the main console to reveal the HDMI ports.
    • You will probably need to lift it on both sides in order for the panel to come loose.
  5. PlayStation VR Processor Unit Cooling Fan Replacement: 5 단계, 이미지 1/1
    • Turn the console over.
    • Unscrew the two 9 mm screws with a PH #000 screwdriver.
  6. PlayStation VR Processor Unit Cooling Fan Replacement: 6 단계, 이미지 1/2 PlayStation VR Processor Unit Cooling Fan Replacement: 6 단계, 이미지 2/2
    • With the plastic opening tool, carefully pry the console shell panel free and lift it away.
  7. PlayStation VR Processor Unit Cooling Fan Replacement: 7 단계, 이미지 1/2 PlayStation VR Processor Unit Cooling Fan Replacement: 7 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using tweezers, carefully pull the multi colored bundled cable from its port connecting the fan to the console.
    • Carefully lift the fan and its wiring from the device.
    • Be mindful of damaging the wires.
    • Take care to keep your fingers away from the fan blades.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Sarah Shand
회원 가입일: 02/20/17
1,885 평판
안내서 7개 작성하였습니다
USF Tampa, Team S3-G1, Sullivan Spring 2017 USF Tampa, Team S3-G1, Sullivan Spring 2017 회원
USFT-SULLIVAN-S17S3G1
3 회원들
안내서 13개 작성하였습니다
댓글 4개
Where do I get a replacement fan tho?
Ponos King - 답글
I think is a 3x3 cm fan, alliexpres has some, but what voltage?
crus - 답글
5V is what i have read
Ethan Amos -
Reference for fan when I have replaced mine : DELTA ELECTRONICS MODEL : ASB0305MA-01 DC 5V 0.19A
herossuperman - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 23
30일 전: 69
전체 시간: 8,770
