소개
A damaged or broken cooling fan can make your system overheat so it is important to replace it if that happens in order to prevent any further damage to the system.
부품
지정된 부품이 없습니다.
On one side of the console (the side adjacent to the fan vent), there will be two 6 mm screws. Unscrew them with a PH #000 screwdriver.
다른 7명이 해당 안내서를 완성하였습니다.
댓글 4개
Where do I get a replacement fan tho?
Ponos King - 답글
5V is what i have read
Reference for fan when I have replaced mine : DELTA ELECTRONICS MODEL : ASB0305MA-01 DC 5V 0.19A
