이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
On one side of the console (the side adjacent to the fan vent), there will be two 6 mm screws. Unscrew them with a PH #000 screwdriver.
Press and slide the side panel (it will have the two ports) back to reveal an additional 6 mm screw.
Unscrew the 6mm screw with a PH #000 screwdriver.
Using a plastic opening tool, carefully pry the panel from the main console to reveal the HDMI ports.
Turn the console over.
Unscrew the two 9 mm screws with a PH #000 screwdriver.
With the plastic opening tool, carefully pry the console shell panel free and lift it away.
Using tweezers, carefully pull the multi colored bundled cable from its port connecting the fan to the console.
Carefully lift the fan and its wiring from the device.
다른 8명이 해당 안내서를 완성하였습니다.
댓글 4개
Where do I get a replacement fan tho?
Ponos King - 답글
5V is what i have read
Reference for fan when I have replaced mine : DELTA ELECTRONICS MODEL : ASB0305MA-01 DC 5V 0.19A
