소개
This guide shows you how to disassemble and replace the display on your Playstation VR headset.
도구
부품
지정된 부품이 없습니다.
Peel back the rubber covering around the lenses to remove the surrounding plastic eyepieces.
Remove the two 6mm screws on the L shaped silver clip to the upper left of the motherboard using the Phillips #000 screwdriver.
Remove the one 6mm screw that is securing the silver clip on the far right side using the Phillips #000 screwdriver.
Remove the three 6mm screws from the motherboard using the Phillips #000 screwdriver.
Unplug the white cable and ribbons from the motherboard(make sure to lift the gates on the ribbons before pulling out).
Unplug the HDMI cable by lifting the gate and pulling gently(there will be adhesive).
Press down firmly on the two clips on the sides of the device to remove the display.
다른 한 분이 해당 안내서를 완성하였습니다.
