소개
This guide will show you how to remove and replace the lenses of the PlayStation VR Headset. This can be a challenging task, but with a little patience it can be done.
부품
지정된 부품이 없습니다.
Peel back the rubber covering around the lenses to remove the surrounding plastic eyepieces.
Using the tweezers, unplug the three (one black bundled, two multi colored bundled) connector cables from their ports along the circuit board.
다른 23명이 해당 안내서를 완성하였습니다.
댓글 21개
Wow..this looks a lot harder than it should be. I bought my PSVR used and the lenses are kinda scuffed up, like the previous owner cleaned them with something not perfectly soft. I was hoping they’d come out easily from the front, but I guess that’s not the case. Thanks for the immensely difficult guide!
Yep, where to buy the lenses?
Where can i buy new lenses for the PSVR?
