소개
This guide applies to the CUH-ZVR2 processor unit.
필요한 것
Place the PlayStation VR processor unit with the I/O (back) side facing up.
Peel the sticker up with a fingernail or a pry tool.
Remove the single J0 screw.
Place the screw in a parts tray to keep it organized.
Use a spudger or a fingernail to lift the pcb in the direction highlighted
Gently separate the metal plate from pcb
Replace the thermal paste if needed.
Use a fingernail or a pry tool to see if the thermal pad is still soft. that means it still conducts heat. if hard, remove and replace the thermal pad
다른 3명이 해당 안내서를 완성하였습니다.
댓글 3개
Hi, is thermal pads being dry could be the reason for this processing unit not turning on? It lits the light for quick millisecond and goes out as i connect the barrel jack. :( I couldn't find any fix yet
Is it neccessary to replace the thermal pad with another pad , or may I use normal thermal paste?
It must be replaced with another new thermal pad of the same thickness, in this case a 2mm pad. If you use thermal paste, there will be a lot of space between the heatsink and the chip, which could cause failures and overheating.
