부품
지정된 부품이 없습니다.
Use your hands to remove the foam piece in the headband.
Use an opening tool to pry the top and bottom trim pieces off of the rear band assembly.
Remove the single 5 mm screw from each of the LED tracker boards using a Phillips #00 screwdriver.
Gently pull up and slide each tracker board outward, away from the center of the band, in order to free it from the rear headband shell.
거의 끝나갑니다!
결론
