주요 콘텐츠로 건너뛰기
PlayStation Vita 3G Antenna Cable Replacement
필요한 것
  1. PlayStation Vita 3G Antenna Cable Replacement, Case Separation: 1 단계, 이미지 2개 중 1개 PlayStation Vita 3G Antenna Cable Replacement, Case Separation: 1 단계, 이미지 2개 중 2개
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita 3G Antenna Cable Replacement: 2 단계, 이미지 3개 중 1개 PlayStation Vita 3G Antenna Cable Replacement: 2 단계, 이미지 3개 중 2개 PlayStation Vita 3G Antenna Cable Replacement: 2 단계, 이미지 3개 중 3개
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita 3G Antenna Cable Replacement: 3 단계, 이미지 2개 중 1개 PlayStation Vita 3G Antenna Cable Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita 3G Antenna Cable Replacement: 4 단계, 이미지 3개 중 1개 PlayStation Vita 3G Antenna Cable Replacement: 4 단계, 이미지 3개 중 2개 PlayStation Vita 3G Antenna Cable Replacement: 4 단계, 이미지 3개 중 3개
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita 3G Antenna Cable Replacement: 5 단계, 이미지 2개 중 1개 PlayStation Vita 3G Antenna Cable Replacement: 5 단계, 이미지 2개 중 2개
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita 3G Antenna Cable Replacement: 6 단계, 이미지 1개 중 1개
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita 3G Antenna Cable Replacement: 7 단계, 이미지 1개 중 1개
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita 3G Antenna Cable Replacement: 8 단계, 이미지 1개 중 1개
    • Separate the front and rear cases.
  9. PlayStation Vita 3G Antenna Cable Replacement, 3G Antenna Cable: 9 단계, 이미지 1개 중 1개
    • Using the pointy end of a spudger, gently pry the 3G antenna cable off of the wireless card.
  10. PlayStation Vita 3G Antenna Cable Replacement: 10 단계, 이미지 1개 중 1개
    • Using the pointy end of a spudger, gently pry the 3G antenna cable off the right button board.
    • Deroute the 3G antenna cable out of the casing and remove it.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Brittany McCrigler
회원 가입일: 03/05/12
89,769 평판
안내서 142개를 작성함
iFixit iFixit 회원
Staff
118 회원들
안내서 19,570개를 작성함
댓글 한 개
I need mine fixed because it has came out but it isn’t a wire it is like a orange thin thing and it won’t clip back in
Jacob Gaming videos 123 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 24
지난 30일: 117
전체 시간: 8,347
