소개
This guide takes you through replacing the battery on the PlayStation Vita.
Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
With the help of a spudger, gently pry off and remove the battery cable retainer on the back casing assembly.
다른 80명이 해당 안내서를 완성하였습니다.
댓글 13개
Great guide. Only problem is this takes very steady hands (something i do not have)
chavis0704 - 답글
This is a great guide. It allowed me to execute the repair and do so without and damage. Just be careful with the triggers they can move and get caught while closing everything up.
Jewon today we have a hack for psvita 3.60 version ONLY !! this allow u download a VPK file that says how much persent your battery is at
With your Vita connected to your PC and the Content manager application running, on windows right click on the vita and then properties and the battery percentage will show up.
