주요 콘텐츠로 건너뛰기
PlayStation Vita Camera Replacement
필요한 것
  1. PlayStation Vita Camera Replacement, Case Separation: 1 단계, 이미지 1/2 PlayStation Vita Camera Replacement, Case Separation: 1 단계, 이미지 2/2
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Camera Replacement: 2 단계, 이미지 1/3 PlayStation Vita Camera Replacement: 2 단계, 이미지 2/3 PlayStation Vita Camera Replacement: 2 단계, 이미지 3/3
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Camera Replacement: 3 단계, 이미지 1/2 PlayStation Vita Camera Replacement: 3 단계, 이미지 2/2
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Camera Replacement: 4 단계, 이미지 1/3 PlayStation Vita Camera Replacement: 4 단계, 이미지 2/3 PlayStation Vita Camera Replacement: 4 단계, 이미지 3/3
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Camera Replacement: 5 단계, 이미지 1/2 PlayStation Vita Camera Replacement: 5 단계, 이미지 2/2
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita Camera Replacement: 6 단계, 이미지 1/1
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Camera Replacement: 7 단계, 이미지 1/1
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita Camera Replacement: 8 단계, 이미지 1/1
    • Separate the front and rear cases.
  9. PlayStation Vita Camera Replacement, Camera: 9 단계, 이미지 1/2 PlayStation Vita Camera Replacement, Camera: 9 단계, 이미지 2/2
    • Release the camera flex cable socket by prying up on the tab with a spudger. Leave the socket open.
  10. PlayStation Vita Camera Replacement: 10 단계, 이미지 1/3 PlayStation Vita Camera Replacement: 10 단계, 이미지 2/3 PlayStation Vita Camera Replacement: 10 단계, 이미지 3/3
    • Using a spudger, gently pry up the camera.
    • Work your way under the camera and along the camera flex cable, using the pointy tip of the spudger to peel away the adhesive, freeing the camera.
    • Carefully lift and remove the camera.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Brittany McCrigler
회원 가입일: 03/05/12
87,961 평판
안내서 132개 작성하였습니다
iFixit iFixit 회원
Community
140 회원들
안내서 16,877개 작성하였습니다
0 Comments
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 16
30일 전: 54
전체 시간: 7,607
