주요 콘텐츠로 건너뛰기
PlayStation Vita Case Separation
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. PlayStation Vita Case Separation, Case Separation: 1 단계, 이미지 1/2 PlayStation Vita Case Separation, Case Separation: 1 단계, 이미지 2/2
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Case Separation: 2 단계, 이미지 1/3 PlayStation Vita Case Separation: 2 단계, 이미지 2/3 PlayStation Vita Case Separation: 2 단계, 이미지 3/3
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Case Separation: 3 단계, 이미지 1/2 PlayStation Vita Case Separation: 3 단계, 이미지 2/2
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Case Separation: 4 단계, 이미지 1/3 PlayStation Vita Case Separation: 4 단계, 이미지 2/3 PlayStation Vita Case Separation: 4 단계, 이미지 3/3
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Case Separation: 5 단계, 이미지 1/2 PlayStation Vita Case Separation: 5 단계, 이미지 2/2
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita Case Separation: 6 단계, 이미지 1/1
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Case Separation: 7 단계, 이미지 1/1
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita Case Separation: 8 단계, 이미지 1/1
    • Separate the front and rear cases.
결론
Brittany McCrigler
회원 가입일: 03/05/12
89,020 평판
안내서 131개 작성하였습니다
iFixit iFixit 회원
Staff
136 회원들
안내서 17,299개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 15
전체 시간: 317
