이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This guide takes you through installing the directional pad (D-Pad) on the PlayStation Vita.
필요한 것
Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
Pry up the left shoulder button casing with a spudger.
Remove the left shoulder button casing.
Using a spudger, lift and release the tab on the ZIF socket sitting on the SIM card reader.
Carefully pull the flex cable out of the ZIF socket, and rest it out of the way.
다른 9명이 해당 안내서를 완성하였습니다.
댓글 한 개
I read this guide from the first to the20th step I haven't tried it yet though
