주요 콘텐츠로 건너뛰기
PlayStation Vita Left Shoulder Button Replacement
필요한 것
  1. PlayStation Vita Left Shoulder Button Replacement, Case Separation: 1 단계, 이미지 1/2 PlayStation Vita Left Shoulder Button Replacement, Case Separation: 1 단계, 이미지 2/2
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Left Shoulder Button Replacement: 2 단계, 이미지 1/3 PlayStation Vita Left Shoulder Button Replacement: 2 단계, 이미지 2/3 PlayStation Vita Left Shoulder Button Replacement: 2 단계, 이미지 3/3
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Left Shoulder Button Replacement: 3 단계, 이미지 1/2 PlayStation Vita Left Shoulder Button Replacement: 3 단계, 이미지 2/2
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Left Shoulder Button Replacement: 4 단계, 이미지 1/3 PlayStation Vita Left Shoulder Button Replacement: 4 단계, 이미지 2/3 PlayStation Vita Left Shoulder Button Replacement: 4 단계, 이미지 3/3
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Left Shoulder Button Replacement: 5 단계, 이미지 1/2 PlayStation Vita Left Shoulder Button Replacement: 5 단계, 이미지 2/2
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita Left Shoulder Button Replacement: 6 단계, 이미지 1/1
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Left Shoulder Button Replacement: 7 단계, 이미지 1/1
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita Left Shoulder Button Replacement: 8 단계, 이미지 1/1
    • Separate the front and rear cases.
  9. PlayStation Vita Left Shoulder Button Replacement, Left Shoulder Button: 9 단계, 이미지 1/3 PlayStation Vita Left Shoulder Button Replacement, Left Shoulder Button: 9 단계, 이미지 2/3 PlayStation Vita Left Shoulder Button Replacement, Left Shoulder Button: 9 단계, 이미지 3/3
    • Pry up the left shoulder button casing with a spudger.
    • Remove the left shoulder button casing.
  10. PlayStation Vita Left Shoulder Button Replacement: 10 단계, 이미지 1/2 PlayStation Vita Left Shoulder Button Replacement: 10 단계, 이미지 2/2
    • Remove the translucent, plastic left shoulder button cover.
  11. PlayStation Vita Left Shoulder Button Replacement: 11 단계, 이미지 1/3 PlayStation Vita Left Shoulder Button Replacement: 11 단계, 이미지 2/3 PlayStation Vita Left Shoulder Button Replacement: 11 단계, 이미지 3/3
    • Release the left shoulder button flex cable socket by using a spudger to pry open the tab.
    • Be careful to not break off this small black tab!
    • Using tweezers, slide the flex cable out of the socket. Do not pull on the black tab! Instead, pull the thin flex cable away from the connector (to the left in this image).
  12. PlayStation Vita Left Shoulder Button Replacement: 12 단계, 이미지 1/2 PlayStation Vita Left Shoulder Button Replacement: 12 단계, 이미지 2/2
    • Using a spudger, gently peel up the left shoulder button from the light adhesive connecting it to casing.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Brittany McCrigler
회원 가입일: 03/05/12
87,961 평판
안내서 132개 작성하였습니다
iFixit iFixit 회원
Community
140 회원들
안내서 16,877개 작성하였습니다
0 Comments
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 28
30일 전: 84
전체 시간: 11,553
