소개
This guide takes you through the process of installing the motherboard.
필요한 것
Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
Using the pointy end of the spudger, disconnect the three antenna cable connectors on top of the wireless card.
Deroute the antenna cables so that they are out of the wireless card casing. Rest the wires out of the way.
Pry up the right shoulder button casing with a spudger and set it aside.
Using the pointy end of a spudger, detach the antenna cable on the right button board.
Remove the antenna cable.
Pry up the left shoulder button casing with a spudger.
Remove the left shoulder button casing.
Using a spudger, lift and release the tab on the ZIF socket sitting on the SIM card reader.
Carefully pull the flex cable out of the ZIF socket, and rest it out of the way.
Using the pointy end of a spudger, pry up and release the GPS antenna cable from the motherboard.
Remove the GPS antenna cable.
다른 38명이 해당 안내서를 완성하였습니다.
11 Comments
in steps 2&3, bottom is top and top is bottom
it should be noted that the memory card should always be taken out before separating the case. I just broke my memory card slot by having a card in there while I was opening the case, there's a tiny bit of overhang that will pull the slot off the motherboard.
Okay My original Motherboard power connector broke. So nothing was wrong with it except the Power connector.
My first buy of the Motherboard screen connector broke off.
The Replacement works well, however the Touch input isn't working, unless I restore the device. After a certain amount of time it becomes unresponsive.
Do anyone have a fix before I get a 3rd replacement.
