주요 콘텐츠로 건너뛰기
PlayStation Vita Right Button Board Replacement
필요한 것
  1. PlayStation Vita Right Button Board Replacement, Case Separation: 1 단계, 이미지 1/2 PlayStation Vita Right Button Board Replacement, Case Separation: 1 단계, 이미지 2/2
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Right Button Board Replacement: 2 단계, 이미지 1/3 PlayStation Vita Right Button Board Replacement: 2 단계, 이미지 2/3 PlayStation Vita Right Button Board Replacement: 2 단계, 이미지 3/3
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Right Button Board Replacement: 3 단계, 이미지 1/2 PlayStation Vita Right Button Board Replacement: 3 단계, 이미지 2/2
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Right Button Board Replacement: 4 단계, 이미지 1/3 PlayStation Vita Right Button Board Replacement: 4 단계, 이미지 2/3 PlayStation Vita Right Button Board Replacement: 4 단계, 이미지 3/3
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Right Button Board Replacement: 5 단계, 이미지 1/2 PlayStation Vita Right Button Board Replacement: 5 단계, 이미지 2/2
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita Right Button Board Replacement: 6 단계, 이미지 1/1
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Right Button Board Replacement: 7 단계, 이미지 1/1
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita Right Button Board Replacement: 8 단계, 이미지 1/1
    • Separate the front and rear cases.
  9. PlayStation Vita Right Button Board Replacement, Wireless Card: 9 단계, 이미지 1/3 PlayStation Vita Right Button Board Replacement, Wireless Card: 9 단계, 이미지 2/3 PlayStation Vita Right Button Board Replacement, Wireless Card: 9 단계, 이미지 3/3
    • Using the pointy end of the spudger, disconnect the three antenna cable connectors on top of the wireless card.
    • Deroute the antenna cables so that they are out of the wireless card casing. Rest the wires out of the way.
  10. PlayStation Vita Right Button Board Replacement: 10 단계, 이미지 1/2 PlayStation Vita Right Button Board Replacement: 10 단계, 이미지 2/2
    • Hook the spudger beneath the tab on the wireless card casing and release the tab.
    • Peel up and remove the wireless card casing.
  11. PlayStation Vita Right Button Board Replacement: 11 단계, 이미지 1/2 PlayStation Vita Right Button Board Replacement: 11 단계, 이미지 2/2
    • Remove the two 4.4mm Phillips #00 screws on the wireless card.
    • The wireless card will naturally pop out at an angle.
    • Pull out the wireless card.
  12. PlayStation Vita Right Button Board Replacement, Right Shoulder Button: 12 단계, 이미지 1/3 PlayStation Vita Right Button Board Replacement, Right Shoulder Button: 12 단계, 이미지 2/3 PlayStation Vita Right Button Board Replacement, Right Shoulder Button: 12 단계, 이미지 3/3
    • Pry up the right shoulder button casing with a spudger and set it aside.
  13. PlayStation Vita Right Button Board Replacement: 13 단계, 이미지 1/1
    • Remove the translucent, plastic right shoulder button cover.
  14. PlayStation Vita Right Button Board Replacement: 14 단계, 이미지 1/3 PlayStation Vita Right Button Board Replacement: 14 단계, 이미지 2/3 PlayStation Vita Right Button Board Replacement: 14 단계, 이미지 3/3
    • Release the right shoulder button flex cable socket by using a spudger to gently pry open the tab.
    • Using tweezers, slide the flex cable out of the socket.
  15. PlayStation Vita Right Button Board Replacement: 15 단계, 이미지 1/2 PlayStation Vita Right Button Board Replacement: 15 단계, 이미지 2/2
    • Using a spudger, gently peel up the right shoulder button from the light adhesive connecting it to casing.
  16. PlayStation Vita Right Button Board Replacement, Right Button Board: 16 단계, 이미지 1/2 PlayStation Vita Right Button Board Replacement, Right Button Board: 16 단계, 이미지 2/2
    • Using the pointy end of a spudger, detach the antenna cable on the right button board.
    • Remove the antenna cable.
  17. PlayStation Vita Right Button Board Replacement: 17 단계, 이미지 1/2 PlayStation Vita Right Button Board Replacement: 17 단계, 이미지 2/2
    • Using a spudger, pry up and release the ZIF socket on the right button board.
    • Gently pull the flex cable out of the socket. Rest the flex cable out of the way.
  18. PlayStation Vita Right Button Board Replacement: 18 단계, 이미지 1/3 PlayStation Vita Right Button Board Replacement: 18 단계, 이미지 2/3 PlayStation Vita Right Button Board Replacement: 18 단계, 이미지 3/3
    • Release the tab on the small flex cable socket by prying up the tab with a spudger.
    • Using tweezers, gently pull the flex cable out of the socket. Rest the flex cable out of the way.
  19. PlayStation Vita Right Button Board Replacement: 19 단계, 이미지 1/3 PlayStation Vita Right Button Board Replacement: 19 단계, 이미지 2/3 PlayStation Vita Right Button Board Replacement: 19 단계, 이미지 3/3
    • Remove the two 5.0mm Phillips #00 screws from the metal bracket securing the right button board to the motherboard.
    • Remove the metal bracket, using a spudger as necessary to lift it out.
  20. PlayStation Vita Right Button Board Replacement: 20 단계, 이미지 1/3 PlayStation Vita Right Button Board Replacement: 20 단계, 이미지 2/3 PlayStation Vita Right Button Board Replacement: 20 단계, 이미지 3/3
    • Use a spudger to free the right button board by prying up from the bottom right corner of board.
    • Gently lift the right button board out.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Brittany McCrigler
회원 가입일: 03/05/12
89,017 평판
안내서 131개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 17,153개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 14
30일 전: 66
전체 시간: 7,817
