주요 콘텐츠로 건너뛰기
PlayStation Vita Speakers Replacement
필요한 것
  1. PlayStation Vita Speakers Replacement, Case Separation: 1 단계, 이미지 1/2 PlayStation Vita Speakers Replacement, Case Separation: 1 단계, 이미지 2/2
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Speakers Replacement: 2 단계, 이미지 1/3 PlayStation Vita Speakers Replacement: 2 단계, 이미지 2/3 PlayStation Vita Speakers Replacement: 2 단계, 이미지 3/3
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Speakers Replacement: 3 단계, 이미지 1/2 PlayStation Vita Speakers Replacement: 3 단계, 이미지 2/2
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Speakers Replacement: 4 단계, 이미지 1/3 PlayStation Vita Speakers Replacement: 4 단계, 이미지 2/3 PlayStation Vita Speakers Replacement: 4 단계, 이미지 3/3
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Speakers Replacement: 5 단계, 이미지 1/2 PlayStation Vita Speakers Replacement: 5 단계, 이미지 2/2
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita Speakers Replacement: 6 단계, 이미지 1/1
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Speakers Replacement: 7 단계, 이미지 1/1
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita Speakers Replacement: 8 단계, 이미지 1/1
    • Separate the front and rear cases.
  9. PlayStation Vita Speakers Replacement, Speakers: 9 단계, 이미지 1/2 PlayStation Vita Speakers Replacement, Speakers: 9 단계, 이미지 2/2
    • Gently insert a spudger along the side of the speaker on the back casing assembly. Pry the speaker off the casing and remove it.
    • The speaker is adhered to the casing with light tape, which may give the speaker light resistance.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Brittany McCrigler
회원 가입일: 03/05/12
89,020 평판
안내서 131개 작성하였습니다
iFixit iFixit 회원
Staff
136 회원들
안내서 17,299개 작성하였습니다
댓글 2개
My Ps vita is still not playing sound with the volume all the way up. Think this could be electrical?
Sarah - 답글
my ps vita 3G model get washed, i dismantle the console and both speakers to let it dry. 1 month later my vita woke up but now the speakers sound bad, is there a way to fix them?
Luis Hernández - 답글
댓글 쓰기
조회 통계:
24 시간 전: 11
7일 전: 37
30일 전: 117
전체 시간: 12,265
