이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This guide takes you through installing the speakers in the PlayStation Vita.
필요한 것
Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
Gently insert a spudger along the side of the speaker on the back casing assembly. Pry the speaker off the casing and remove it.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 2개
my ps vita 3G model get washed, i dismantle the console and both speakers to let it dry. 1 month later my vita woke up but now the speakers sound bad, is there a way to fix them?
