주요 콘텐츠로 건너뛰기
PlayStation Vita Wi-Fi Antenna Replacement
필요한 것
  1. PlayStation Vita Wi-Fi Antenna Replacement, Case Separation: 1 단계, 이미지 2개 중 1개 PlayStation Vita Wi-Fi Antenna Replacement, Case Separation: 1 단계, 이미지 2개 중 2개
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Wi-Fi Antenna Replacement: 2 단계, 이미지 3개 중 1개 PlayStation Vita Wi-Fi Antenna Replacement: 2 단계, 이미지 3개 중 2개 PlayStation Vita Wi-Fi Antenna Replacement: 2 단계, 이미지 3개 중 3개
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Wi-Fi Antenna Replacement: 3 단계, 이미지 2개 중 1개 PlayStation Vita Wi-Fi Antenna Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Wi-Fi Antenna Replacement: 4 단계, 이미지 3개 중 1개 PlayStation Vita Wi-Fi Antenna Replacement: 4 단계, 이미지 3개 중 2개 PlayStation Vita Wi-Fi Antenna Replacement: 4 단계, 이미지 3개 중 3개
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Wi-Fi Antenna Replacement: 5 단계, 이미지 2개 중 1개 PlayStation Vita Wi-Fi Antenna Replacement: 5 단계, 이미지 2개 중 2개
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita Wi-Fi Antenna Replacement: 6 단계, 이미지 1개 중 1개
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Wi-Fi Antenna Replacement: 7 단계, 이미지 1개 중 1개
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita Wi-Fi Antenna Replacement: 8 단계, 이미지 1개 중 1개
    • Separate the front and rear cases.
  9. PlayStation Vita Wi-Fi Antenna Replacement, Wi-Fi Antenna: 9 단계, 이미지 2개 중 1개 PlayStation Vita Wi-Fi Antenna Replacement, Wi-Fi Antenna: 9 단계, 이미지 2개 중 2개
    • Using the pointy end of a spudger, gently pry the white Wi-Fi antenna cable connecotr off of the wireless card.
    • Deroute the Wi-Fi antenna cable out of the black plastic casing.
  10. PlayStation Vita Wi-Fi Antenna Replacement: 10 단계, 이미지 2개 중 1개 PlayStation Vita Wi-Fi Antenna Replacement: 10 단계, 이미지 2개 중 2개
    • Using the pointy end of the spudger, gently pry the Wi-Fi antenna cable connector off of the left button board at the connection.
    • Remove the Wi-Fi antenna cable.
결론
작성자
3다른 기여자 명과 함께
Brittany McCrigler
회원 가입일: 03/05/12
89,748 평판
안내서 142개를 작성함
iFixit iFixit 회원
Staff
118 회원들
안내서 19,526개를 작성함
댓글 4개
what about the ps vita slim 2000 model? ive got no wifi at all but cant see a teardown to find the wifi module
Keegan - 답글
Is WiFi / 3G antenna cable: UFL/IPEX to UFL/IPEX 1.3mm? What is the white cable length?
samohvalov2010 - 답글
Yeah this is not a Wifi antenna cable. The "wireless card" only does 3G and GPS/Glonass. Wifi controller is on the mainboard itself.
computer1up - 답글
^ okay that explains a lot, i thought i was missing parts in my PSV1000 wifi
Bronson - 답글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 30
지난 30일: 78
전체 시간: 8,907
