주요 콘텐츠로 건너뛰기
Playstation 3 Power Supply Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. Playstation 3 Power Supply Replacement, Top Cover: 1 단계, 이미지 1/2 Playstation 3 Power Supply Replacement, Top Cover: 1 단계, 이미지 2/2
    • Remove the rubber screw cover near the hard drive cover with a spudger.
  2. Playstation 3 Power Supply Replacement: 2 단계, 이미지 1/1
    • Remove the screw holding the top cover in place with a Torx T10 screwdriver.
  3. Playstation 3 Power Supply Replacement: 3 단계, 이미지 1/2 Playstation 3 Power Supply Replacement: 3 단계, 이미지 2/2
    • Slide the top cover down about half an inch.
    • Lift the cover off of the PS3.
  4. Playstation 3 Power Supply Replacement: 4 단계, 이미지 1/2 Playstation 3 Power Supply Replacement: 4 단계, 이미지 2/2
    • Remove the seven screws in the top cover with a Phillips #2 screwdriver.
    • One of the screws is shorter than the others. The short screw is marked in yellow.
  5. Playstation 3 Power Supply Replacement: 5 단계, 이미지 1/3 Playstation 3 Power Supply Replacement: 5 단계, 이미지 2/3 Playstation 3 Power Supply Replacement: 5 단계, 이미지 3/3
    • You can now lift off the top cover.
  6. Playstation 3 Power Supply Replacement, Power Supply: 6 단계, 이미지 1/2 Playstation 3 Power Supply Replacement, Power Supply: 6 단계, 이미지 2/2
    • Unplug the white wires connected to the wireless board. There are two sets of wires: one set in the front, one in the back.
    • Push down the tab on the connector to disconnect the wires.
    • Remove the two screws on the front of the power supply.
  7. Playstation 3 Power Supply Replacement: 7 단계, 이미지 1/1
    • Remove the screws on the back of the power supply with a Phillips #2 screwdriver.
  8. Playstation 3 Power Supply Replacement: 8 단계, 이미지 1/2 Playstation 3 Power Supply Replacement: 8 단계, 이미지 2/2
    • Remove the power supply by lifting it straight up.
결론
다른 2명이 해당 안내서를 완성하였습니다.
iDeleted
회원 가입일: 07/07/10
2,101 평판
안내서 39개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,479
