주요 콘텐츠로 건너뛰기
Playstation Classic Controller Cord Replacement
필요한 것
  1. Playstation Classic Controller Cord Replacement, Controller Cord: 1 단계, 이미지 1/3 Playstation Classic Controller Cord Replacement, Controller Cord: 1 단계, 이미지 2/3 Playstation Classic Controller Cord Replacement, Controller Cord: 1 단계, 이미지 3/3
    • Turn the controller over so that the screws are facing up.
  2. Playstation Classic Controller Cord Replacement: 2 단계, 이미지 1/1
    • Use a small Phillips #0 screwdriver to remove the eight Xmm screws.
    • Make sure to store the screws in a safe place so they are not lost before reassembly.
  3. Playstation Classic Controller Cord Replacement: 3 단계, 이미지 1/3 Playstation Classic Controller Cord Replacement: 3 단계, 이미지 2/3 Playstation Classic Controller Cord Replacement: 3 단계, 이미지 3/3
    • Use the Jimmy tool to take the back part off and get into the controller.
    • It shouldn’t take too much force to remove the back part. Make sure all screws are taken out beforehand so you avoid hurting yourself or damaging the controller.
  4. Playstation Classic Controller Cord Replacement: 4 단계, 이미지 1/1
    • You will notice that the controller cord is plugged into a Micro USB port on the controller motherboard.
  5. Playstation Classic Controller Cord Replacement: 5 단계, 이미지 1/3 Playstation Classic Controller Cord Replacement: 5 단계, 이미지 2/3 Playstation Classic Controller Cord Replacement: 5 단계, 이미지 3/3
    • To unplug the cord from the controller motherboard, carefully take the cord out from in between the small pegs that it is nestled into.
    • When unplugging the cord, hold the controller so that no significant pressure is being applied to the motherboard that will damage it.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Maxwell Webb
회원 가입일: 04/22/19
631 평판
안내서 5개 작성하였습니다
Cal Poly, Team S2-G8, Maness Spring 2019 Cal Poly, Team S2-G8, Maness Spring 2019 회원
CPSU-MANESS-S19S2G8
2 회원들
안내서 22개 작성하였습니다
댓글 2개
Will this fix the controller being unresponsive?
Jamal Saeed - 답글
maybe but It depends
enrique bengaura -
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 23
30일 전: 73
전체 시간: 5,959
