주요 콘텐츠로 건너뛰기
Playstation Classic Motherboard Replacement
필요한 것
  1. Playstation Classic Motherboard Replacement, Motherboard: 1 단계, 이미지 1/1
    • Flip the console so its back is facing up.
  2. Playstation Classic Motherboard Replacement: 2 단계, 이미지 1/1
    • Remove the five 3mm screws using the Phillips #00 screwdriver.
    • Make sure to keep your screws together in a secure location to avoid misplacement.
  3. Playstation Classic Motherboard Replacement: 3 단계, 이미지 1/3 Playstation Classic Motherboard Replacement: 3 단계, 이미지 2/3 Playstation Classic Motherboard Replacement: 3 단계, 이미지 3/3
    • Remove the back plate from the rest of the console using your hands or the Jimmy tool.
  4. Playstation Classic Motherboard Replacement: 4 단계, 이미지 1/1
    • Unscrew the motherboard's five 3mm screws with the Phillips #00 screwdriver.
    • Be careful not to apply too much force. The motherboard is flimsy and easy to break.
    • Keep track of your screws once they are removed.
  5. Playstation Classic Motherboard Replacement: 5 단계, 이미지 1/3 Playstation Classic Motherboard Replacement: 5 단계, 이미지 2/3 Playstation Classic Motherboard Replacement: 5 단계, 이미지 3/3
    • Carefully remove the motherboard from the the rest of the console using your hands or the Jimmy tool.
  6. Playstation Classic Motherboard Replacement: 6 단계, 이미지 1/3 Playstation Classic Motherboard Replacement: 6 단계, 이미지 2/3 Playstation Classic Motherboard Replacement: 6 단계, 이미지 3/3
    • The motherboard is connected to its metal protective casing with sticky pads. No tools are required to remove it.
    • Pull the metal casing off the motherboard.
    • Remember to be gentle when handling the motherboard.
    Alguien sabe repara puertos USB no me reconoce nada ni los controles
    Juan Abraham Avila Yampey - 답글
    Qualcuno sa come riparare le porte USB, non riconosce nulla o i controlli
    LORENZO MANCUSI - 답글
결론
다른 2명이 해당 안내서를 완성하였습니다.
Maxwell Webb
회원 가입일: 04/22/19
631 평판
안내서 5개 작성하였습니다
Cal Poly, Team S2-G8, Maness Spring 2019 Cal Poly, Team S2-G8, Maness Spring 2019 회원
CPSU-MANESS-S19S2G8
2 회원들
안내서 22개 작성하였습니다
댓글 2개
where do you get a ps1 classic mini motherboard ?
blaqdemon69 - 답글
You would probably be cannibalizing a broken PS1 Classic for its motherboard. Perhaps "Parts Only."
Matt Latsha -
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 16
30일 전: 71
전체 시간: 3,430
