주요 콘텐츠로 건너뛰기
Playstation Classic Open Button Replacement
필요한 것
  1. Playstation Classic Open Button Replacement, Motherboard: 1 단계, 이미지 1/1
    • Flip the console so its back is facing up.
  2. Playstation Classic Open Button Replacement: 2 단계, 이미지 1/1
    • Remove the five 3mm screws using the Phillips #00 screwdriver.
    • Make sure to keep your screws together in a secure location to avoid misplacement.
  3. Playstation Classic Open Button Replacement: 3 단계, 이미지 1/3 Playstation Classic Open Button Replacement: 3 단계, 이미지 2/3 Playstation Classic Open Button Replacement: 3 단계, 이미지 3/3
    • Remove the back plate from the rest of the console using your hands or the Jimmy tool.
  4. Playstation Classic Open Button Replacement: 4 단계, 이미지 1/1
    • Unscrew the motherboard's five 3mm screws with the Phillips #00 screwdriver.
    • Be careful not to apply too much force. The motherboard is flimsy and easy to break.
    • Keep track of your screws once they are removed.
  5. Playstation Classic Open Button Replacement: 5 단계, 이미지 1/3 Playstation Classic Open Button Replacement: 5 단계, 이미지 2/3 Playstation Classic Open Button Replacement: 5 단계, 이미지 3/3
    • Carefully remove the motherboard from the the rest of the console using your hands or the Jimmy tool.
  6. Playstation Classic Open Button Replacement: 6 단계, 이미지 1/3 Playstation Classic Open Button Replacement: 6 단계, 이미지 2/3 Playstation Classic Open Button Replacement: 6 단계, 이미지 3/3
    • The motherboard is connected to its metal protective casing with sticky pads. No tools are required to remove it.
    • Pull the metal casing off the motherboard.
    • Remember to be gentle when handling the motherboard.
  7. Playstation Classic Open Button Replacement, Open Button: 7 단계, 이미지 1/3 Playstation Classic Open Button Replacement, Open Button: 7 단계, 이미지 2/3 Playstation Classic Open Button Replacement, Open Button: 7 단계, 이미지 3/3
    • Remove the motherboard using the previous guide and isolate the top shell of the casing.
    • Use the Spudger to apply pressure inwards on the three plastic clips highlighted in the red circles.
  8. Playstation Classic Open Button Replacement: 8 단계, 이미지 1/3 Playstation Classic Open Button Replacement: 8 단계, 이미지 2/3 Playstation Classic Open Button Replacement: 8 단계, 이미지 3/3
    • After all three clips are pushed in, apply pressure on the cylindrical piece circled in red.
    • Push softly on the button till a small gap is created on the other side.
    • You are not trying to fully remove the Open Button in this step.
  9. Playstation Classic Open Button Replacement: 9 단계, 이미지 1/3 Playstation Classic Open Button Replacement: 9 단계, 이미지 2/3 Playstation Classic Open Button Replacement: 9 단계, 이미지 3/3
    • Use the black spudger to softly pry out the open button from the top of the casing.
    • Once enough of a gap has been created, use your fingers to grab and slowly remove the open piece.
    • An unrestrained string is under the open button and can fall out easily. To avoid losing the spring, complete this step on a flat surface and be gentle while removing the open button.
결론
Maxwell Webb
회원 가입일: 04/22/19
631 평판
안내서 5개 작성하였습니다
Cal Poly, Team S2-G8, Maness Spring 2019 Cal Poly, Team S2-G8, Maness Spring 2019 회원
CPSU-MANESS-S19S2G8
2 회원들
안내서 22개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 20
전체 시간: 1,043
