주요 콘텐츠로 건너뛰기
Plugging in Shure SM58 XLR Cable
  1. Plugging in Shure SM58 XLR Cable, XLR Cable Plug In: 1 단계, 이미지 1개 중 1개
    • Make sure you have a proper three pin XLR cable.
    • Grab the female end of the cable (plug with three holes).
  2. Plugging in Shure SM58 XLR Cable: 2 단계, 이미지 1개 중 1개
    • Line up the pins in the end of the microphone (microphone connecter) with the holes in the XLR cable.
  3. Plugging in Shure SM58 XLR Cable: 3 단계, 이미지 1개 중 1개
    • Once the pins are aligned, push the cable into the bottom end of the microphone. You should hear a click.
결론
To disconnect the cable from the microphone, follow the instructions in reverse.
다른 13명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
nat coll
회원 가입일: 09/27/12
811 평판
안내서 14개를 작성함
Cal Poly, Team 7-53, Forte Fall 2012 Cal Poly, Team 7-53, Forte Fall 2012 회원
CPSU-FORTE-F12S7G53
5 회원들
안내서 33개를 작성함
21가이드 댓글
When disconnecting the cable - press the little latch (pointing towards you in the last picture) to release and then pull the cable out.
harrywwc - 답글
Is this April's fool? XD
s6963172 - 답글
how i repair the PG48 the XLR conector moves in and out when the cable ar plugged. The conector male in the microphone have an screw but that one not works...
What am i do?
If you have an idea to the answer or any tip to resolve this trouble feel fre to tweet me.
@ Theradioholic
on
#Twitter
Santiago Morales - 답글
I know a few people who would see this and still screw it up.
jimboc - 답글
do it in reverse? you have to press the button though on the male end...
Michael Fox - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 37
지난 30일: 157
전체 시간: 69,900
