주요 콘텐츠로 건너뛰기
Plugging in Shure SM58 XLR Cable
  1. Plugging in Shure SM58 XLR Cable, XLR Cable Plug In: 1 단계, 이미지 1/1
    • Make sure you have a proper three pin XLR cable.
    • Grab the female end of the cable (plug with three holes).
  2. Plugging in Shure SM58 XLR Cable: 2 단계, 이미지 1/1
    • Line up the pins in the end of the microphone (microphone connecter) with the holes in the XLR cable.
  3. Plugging in Shure SM58 XLR Cable: 3 단계, 이미지 1/1
    • Once the pins are aligned, push the cable into the bottom end of the microphone. You should hear a click.
결론
To disconnect the cable from the microphone, follow the instructions in reverse.
다른 13명이 해당 안내서를 완성하였습니다.
nat coll
회원 가입일: 09/27/12
642 평판
안내서 14개 작성하였습니다
Cal Poly, Team 7-53, Forte Fall 2012 Cal Poly, Team 7-53, Forte Fall 2012 회원
CPSU-FORTE-F12S7G53
5 회원들
안내서 20개 작성하였습니다
댓글 21개
When disconnecting the cable - press the little latch (pointing towards you in the last picture) to release and then pull the cable out.
harrywwc - 답글
Is this April's fool? XD
s6963172 - 답글
how i repair the PG48 the XLR conector moves in and out when the cable ar plugged. The conector male in the microphone have an screw but that one not works...
What am i do?
If you have an idea to the answer or any tip to resolve this trouble feel fre to tweet me.
@ Theradioholic
on
#Twitter
Santiago Morales - 답글
I know a few people who would see this and still screw it up.
jimboc - 답글
do it in reverse? you have to press the button though on the male end...
Michael Fox - 답글
Will this work with an Audio-Technica ATM-410, or just the Shure?
cbrislain - 답글
Just Shure. On Audio-Technica you have to rotate the plug six times clockwise and whisper a few nice words into it before plugging it in. I've always found that lullabies work quite well.
staale -
I have a 1/4 adapter on my Shure, is that process different? I can't seem to make the male 1/4" connect to the female XLR
JON CAMPBELL - 답글
Push harder.
staale -
Some of us are musicians , so we appreciate the help
tomandlindafirme - 답글
When do you hear the sound from it?
Charlie Green - 답글
Bloomin' eck.... & I've been using cellotape, Blu Tak and super glue. No wonder I had to revert to the megaphone all the time
george sandoz - 답글
I don't know about you lando77 but I always blow on the female end (the cable end with the holes) to blow dry any moisture out. What good does it do to blow on the male pins?
darryltrimm - 답글
Do these instructions work for the ElectroVoice EV 635A as well?
carterjim - 답글
This is useless. Why didn't you post a video that shows the process.
mperloe - 답글
Wow!!! Thank you so much! This is really great information. Now I won't have to hire people to come do this for me anymore. Can you post a video of how to put the microphone on a stand?
dhoffman98 - 답글
Thanks for posting this, I recently ran out of toilet tissue and have been using my Shure SM58 Owner's Manual. You're a lifesaver!
hemightbefluffy - 답글
He's holding the plug with his right hand. But what if I'm left handed. Do I need to rotate it? Or should I switch what side I'm standing on?
Bob DeMaa - 답글
Managed it on 5th attempt , now what the heck do I do with the other end of the cable ???
gary blair - 답글
are these instructions specifically for drummers or can anybody use them?
Cedric the Dead - 답글
Hola ..he comprado un micrófono shure pg48 1i no se porque al conectar con el cable no se escucha ningun sonido..
cristianbocanel51 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 27
30일 전: 153
전체 시간: 67,486
