주요 콘텐츠로 건너뛰기
Plum Optimax 10 Battery Replacement
필요한 것
  1. Plum Optimax 10 Battery Replacement, Back Cover: 1 단계, 이미지 1/2 Plum Optimax 10 Battery Replacement, Back Cover: 1 단계, 이미지 2/2
    • Use a metal spudger to remove the small panels to the immediate left and right side of the camera.
  2. Plum Optimax 10 Battery Replacement: 2 단계, 이미지 1/2 Plum Optimax 10 Battery Replacement: 2 단계, 이미지 2/2
    • Use a metal spudger to begin lifting the back cover.
    • Then, create leverage and gently remove the entire cover.
  3. Plum Optimax 10 Battery Replacement, Battery: 3 단계, 이미지 1/2 Plum Optimax 10 Battery Replacement, Battery: 3 단계, 이미지 2/2
    • Remove electrical tape placed around the battery to keep it in place.
  4. Plum Optimax 10 Battery Replacement: 4 단계, 이미지 1/2 Plum Optimax 10 Battery Replacement: 4 단계, 이미지 2/2
    • Use the spudger as a wedge underneath the battery to assist in removal.
    • Once loosened with the spudger, the battery is now removed from the device.
    • Always use a plastic opening tool or nylon spudger to remove batteries. Metal tools can puncture a battery and potentially catch on fire.
결론
Samantha Wright
회원 가입일: 11/06/18
243 평판
안내서 2개 작성하였습니다
IUPUI, Team S1-G4, Hovde Fall 2018 IUPUI, Team S1-G4, Hovde Fall 2018 회원
IUPUI-HOVDE-F18S1G4
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 10
전체 시간: 442
