주요 콘텐츠로 건너뛰기
Plum Optimax 10 Motherboard Replacement
필요한 것
  1. Plum Optimax 10 Motherboard Replacement, Back Cover: 1 단계, 이미지 1/2 Plum Optimax 10 Motherboard Replacement, Back Cover: 1 단계, 이미지 2/2
    • Use a metal spudger to remove the small panels to the immediate left and right side of the camera.
  2. Plum Optimax 10 Motherboard Replacement: 2 단계, 이미지 1/2 Plum Optimax 10 Motherboard Replacement: 2 단계, 이미지 2/2
    • Use a metal spudger to begin lifting the back cover.
    • Then, create leverage and gently remove the entire cover.
  3. Plum Optimax 10 Motherboard Replacement, Motherboard: 3 단계, 이미지 1/2 Plum Optimax 10 Motherboard Replacement, Motherboard: 3 단계, 이미지 2/2
    • Use flathead screwdriver tool to remove the three 2.5 mm screws shown in the photo. Two screws are located at the base of the motherboard and there is one screw located at the top.
  4. Plum Optimax 10 Motherboard Replacement: 4 단계, 이미지 1/1
    • Once screws are removed, carefully remove the motherboard out of encasing.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Samantha Wright
회원 가입일: 11/06/18
243 평판
안내서 2개 작성하였습니다
IUPUI, Team S1-G4, Hovde Fall 2018 IUPUI, Team S1-G4, Hovde Fall 2018 회원
IUPUI-HOVDE-F18S1G4
3 회원들
안내서 6개 작성하였습니다
댓글 한 개
This document is incomplete. It does not detail removing the cables connected to the motherboard.
Before the motherboard can be removed from the case, the Digitizer, the LCD and the power and camera cables must also be removed. the speakers, vibrator and Mic can come out with the motherboard.
George Earl Martin - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 179
