주요 콘텐츠로 건너뛰기
Plunger and O-ring Replacement Guide
필요한 것
  1. Plunger and O-ring Replacement Guide, Plunger and O-ring: 1 단계, 이미지 1개 중 1개
    • Place the blaster upside down on the table, and remove the screw in the bottom of the handle
    • Remove the battery door and take the batteries out.
  2. Plunger and O-ring Replacement Guide: 2 단계, 이미지 3개 중 1개 Plunger and O-ring Replacement Guide: 2 단계, 이미지 3개 중 2개 Plunger and O-ring Replacement Guide: 2 단계, 이미지 3개 중 3개
    • Set the blaster on its side with the screws facing up (the blaster will be placed on its left side). Remove all 14 phillips head, 8.2 mm screws and set them aside.
    • Lift the side of the blaster off exposing its internal parts.
  3. Plunger and O-ring Replacement Guide: 3 단계, 이미지 1개 중 1개
    • Remove the two phillips head, 8.2 mm screws holding the barrel in place.
  4. Plunger and O-ring Replacement Guide: 4 단계, 이미지 2개 중 1개 Plunger and O-ring Replacement Guide: 4 단계, 이미지 2개 중 2개
    • Lift the barrel and plunger strait up being carful to not lose the locking spring.
    • Pull the plunger out of the barrel
  5. Plunger and O-ring Replacement Guide: 5 단계, 이미지 1개 중 1개
    • At this point you will be able to tell whether the O-ring has failed or if the plunger has broken.
    • If the O-ring has failed, simply buy a replacement O-ring of appropriate size from a hardware store and slip it over the end of the plunger.
    • If the plunger has broken see step 6
  6. Plunger and O-ring Replacement Guide: 6 단계, 이미지 1개 중 1개
    • Attempting to glue the plunger will most likely result in a bad O-ring seal causing the blaster to not function correctly.
    • The best course of action would be to obtain an new plunger and replace it.
    • Be sure to put the locking mechanism on in the correct orientation.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Nicholas Samokyszyn
회원 가입일: 02/24/14
359 평판
안내서 3개를 작성함
Michigan Tech, Team 5-8, Lauer Spring 2014 Michigan Tech, Team 5-8, Lauer Spring 2014 회원
MTU-LAUER-S14S5G8
3 회원들
안내서 13개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 25
전체 시간: 3,098
